Somfy Integration Error
I’ve installed the somfy integration from the standard integrations in Home Assistant to control my electric blinds but keep seeing this error in the server logs.
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 236, in async_setup
    result = await component.async_setup_entry(hass, self)  # type: ignore
  File "/usr/src/homeassistant/homeassistant/components/somfy/__init__.py", line 84, in async_setup_entry
    await config_entry_oauth2_flow.async_get_config_entry_implementation(
  File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 379, in async_get_config_entry_implementation
    raise ValueError("Implementation not available")
ValueError: Implementation not available```
Have I missed something or has the API changed
