Somfy Overkiz integration instructions?
Are there some detailed instructions for the Somfy Overkiz integration? I’ve tried adding it in integrations but it asks for a username and password. I have no idea what username and password it is referring to.
Which hub do you have? @bphillips921. You can only use the Overkiz integration if you have a hub that uses the Overkiz server, e.g. Somfy.
I’m using the Somfy MyLink RTS hub
Isn’t there a Somfy Mylink integration? I don’t think that Overkiz does support this.
Thanks for the help!
