Somfy RTS with Overkiz - problem open / close
I have 2 Somfy Tilt 50 RTS motors controlling the tilt of 2 Venetian blinds, and a Connectivity Kit to control them via the Tahoma app. I want to integrate this into Home Assistant via Overkiz.
I can find the 2 motors with no problem and can add them to the dashboard.
The problem is with the open and close command, as the motor is only briefly initiated and then stops, so not fully closing / opening the blind (as it does in the Tahoma app). To close the blind I have the trigger the button multiple times. The MY and stop button works correctly. I also have an exterior shutter (also RTS) which does fully close and open with one button trigger.
Question: is this a bug, or is this some limitation of the tilt function in Overkiz? Is there a way I can fix this?
Best to create an issue on GitHub to track this problem. In theory, if it works via the app, it should be possible to mimick that behavior via Home Assistant.
