Hi All
I have somfy Controlled Venation Blinds all over my home, just the ones that open and close. The problem is they don’t report a state so you can never work out in Home Assistant if they are open or closed. Not a huge issue but annoying all the same. but what is really annoying is in the Tahoma App you can select Open to a predetermined position or Close but in Home Assistant via the OverKiz Custom Integration the two options are: Open to the predetermined position or Tilt. so if you want to close them you need to repeat the Tilt option a number of times and sometimes they don’t close all the way due to multiple calls to multiple blinds.
In Apple Home you can create a Shortcut to call the close option from the App and this works well. But obviously needs to be on all home occupants phones as you cant run app options from the Home Hub.
Sine the Somfy control is kept in the cloud (it must be as I can control when away from home) why is there not a close option anywhere? of am I missing it.
Thanks in advance for any help.
Mike
