Hello, @s3bi77
No, it didnt happen, never had an inverted signal.
Just do try to change the yaml please and report back so I can add it to the notes
Also, thank you for your purchase!
Hello, @s3bi77
Weirdly enough the second garage opener I have is returning the status correctly. I doublechecked everything but there is nothing wrongly plugged in on the first one. I also wasn’t able to find a setting in Sommers User manual to switch the output on the opener.
Just switching the value in software is now enough and it works as expected.
The Sommer 550L has the same PCB incl. Revision as the S 9050 Pro. Also the Stop functionality is not working in the same way as M3c4tr0x already reported on your GitHub Repo. Didn’t have the time yet to investigate if it is possible to solve.
Hello. Ordered one on Tindie (wifi only as I have no ethernet cable routed for now) and uploaded my compiled version of ESPHome using provided yaml.
I have Aperto 800 XL and there is a big capacitor lying next to keypad connector, so the module cannot be inserted fully. However, capacitor can be moved to be vertical, and the module inserted fully so it clicks.
It works flawlessly, and i want to extend BIG THANKS for this project! It saved me a lot of money for the 2 Sommer modules I would need otherwise, and a lot of time spent tinkering (which I don't have currently).
EPIC!
