Sonoff 4CH reset's relay after connection/singnal loss or HAS reboot
I placed my Sonoff 4Ch outdoors on the backside of the garden. The WiFi signal is not the best over there (-83dBi). but every time (completely random) when it loses signal the onboard relay switches to “off” . This is no problem when the relay was “off” before this reboot, but when we turned the relay to “on” and after the connection loss (when we aren’t at home for example) it’s “off”.
This also seems to happen when i reboot Home Assistant.
So the question for now, what should be the best reason to recover the last relay state before the WiFi connection is lost .
loss
nobody with the same problem, or a solution for it
Hi, I am seeing the same problem with Sonoff 4ch, since recent time it became obvious that it resets the switches off along with loosing signal.
From startup log noted below warnings:
INFO ESPHome 2023.9.3
INFO Reading configuration /config/esphome/sonoff4ch.yaml...
WARNING ESP8266: Pin 9 (9-10) might already be used by the flash interface in QUAD IO flash mode.
WARNING ESP8266: Pin 10 (9-10) might already be used by the flash interface in QUAD IO flash mode.
Can anyone suggest on what may be causing this behaviour ?
