Has anyone sucessfully flashed ESPHome to the Sonoff 4chPro R3?
i do not have the 4ChPro R3 but the 4Ch R3, the config should be similar.
take a look at tasmota docs, when it comes to pins and flashing instructions, since this is useful when creating the config in esphome.
for reference this is my config for 4chr3
substitutions:
board: esp8285
packages:
common: !include ../../common-8285.yaml
logger: !include ../../common/logger.yaml
wifi: !include ../../common/wifi.yaml
captive_portal: !include ../../common/captive_portal.yaml
#web_server: !include ../../common/web_server.yaml
status_led:
pin:
number: GPIO13
inverted: True
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
on_press:
then:
- lambda: |-
if (id(use_relay_1).state) {
id(relay_1).toggle();
- platform: gpio
pin:
number: GPIO9
mode: INPUT_PULLUP
inverted: True
on_press:
then:
- lambda: |-
if (id(use_relay_2).state) {
id(relay_2).toggle();
- platform: gpio
pin:
number: GPIO10
mode: INPUT_PULLUP
inverted: True
on_press:
then:
- lambda: |-
if (id(use_relay_3).state) {
id(relay_3).toggle();
- platform: gpio
pin:
number: GPIO14
mode: INPUT_PULLUP
inverted: True
on_press:
then:
- lambda: |-
if (id(use_relay_4).state) {
id(relay_4).toggle();
- platform: status
switch:
- platform: gpio
pin: GPIO12
- platform: gpio
pin: GPIO5
- platform: gpio
pin: GPIO4
- platform: gpio
pin: GPIO15
name: "Use Relay 1"
entity_category: config
restore_mode: RESTORE_DEFAULT_ON
optimistic: true
name: "Use Relay 2"
optimistic: true
name: "Use Relay 3"
optimistic: true
name: "Use Relay 4"
optimistic: true
Thanks. I was having difficulty finding GPIO0. [He who must not be named] kept me grounding the wrong ESP pin. (Almost Intelligent kept insisting that GPIO0 is always ESP pin 25 .)
I would appreciate it if you would share your 8285 package file.
There is considerable difference in the five Sonoff 4CH modules that I have. When I built my irrigation controller a few years ago I bought three of the 4CHPRO v1. They flashed ESPHome easily. One of the boards failed and I wanted to simply replace it. Except the V1 board is no longer available. I bought an R2 module on eBay without doing my research. The 4CHR2 pro only switches the line voltage, while the R1 was dry relay contacts. Apparently the 4CHR2 -non PRO- still exposed dry relay contacts, but I couldn't find one. So, I tried the PRO R3 only to discover the ESP was a bare chip and not the ESP12 module previous Sonoff's used. And identifying GPIO0 became an obstacle.
I don't use Tasmota, so the solution to look there didn't occur to me.
the content is just
esp8266:
board: esp8285
i do not use tasmota but the documentation they have helped me when i looked into pin assignments etc. it helps a lot.
