Sonoff AirGuard TH SNZB-02DR2 with Remote Temperature & Humidity Display
Thought I would create a dedicated thread to make this info easier to find. I have two of these AirGuard TH SNZB-02DR2 which I got to pair with AirGuard TH Pressure SNZB-02M for indoor and outdoor temperature and humidity readings on the one display. I’ve also got a SNZB-02LD to monitor my pool from one of these displays. The AirGuard TH SNZB-02DR2 has just had firmware update to 1.0.5 this week. If you are looking to set up the remote temperature and humidity readings, Sonoff have an official guide for both ZHA like I’m using and Z2M. You need their custom quirks and a blueprint template to set up the automation for remote temperature and humidity readings. Easy enough to do.
