@Greywood I reply in a new post since as a new member I am only allowed to make three replies to same topic. However, this code is working better. I will post an updated version later this week with all features enabled (set temperature unit, set temperature range, set temperature calibration).
eWeLink BMT01 BLE BBQ Thermometer Client version 2026-05-03 rev B
Re-implemented from the eWeLink JS bundle (output.js, Hermes bytecode).
Auth channel:
AES-128-CBC, key=MD5(apikey).hexdigest() → bytes, IV=b'0000000000000000'
Control channel:
Inbound/outbound frame format:
[cmd_lo, cmd_hi, len_lo, len_hi, ...XOR-encrypted-payload...]
XOR key: MD5(apikey) as 16 raw bytes, applied per 16-byte block
→ encryptUtils.encrypt/decrypt in output.js (line 5384648)
→ convertMD5ToBytes(MD5(apikey).toString()) in output.js
Payload: [flags_byte, rx_tsn, ...payloadContent...]
flags byte: bit0 = source (0=APP, 1=DEVICE)
bit1 = needResponse (0=False, 1=True)
(byteToBits LSB-first, output.js line 638586)
Temperature (PUSH, source=DEVICE, byte5=0xD4):
payload_content = [lo1,hi1, lo2,hi2, lo3,hi3, lo4,hi4]
uint16 LE = °C directly. Sentinels: 0xFFFF NOT_ACTIVE, 0xFFFE TOO_HIGH,
0xFFFD TOO_LOW, 0x0FFF INVALID.
Temperature (RESP, source=APP, byte5=0x3D):
Same uint16-LE °C values but each probe's two bytes are XOR'd with a
per-probe 2-byte mask before embedding in the payload. Masks are
device-specific: mask[i] = MD5(apikey)[2+i*2:4+i*2] XOR secondary_key[i*2:i*2+2]
where secondary_key = 38 A3 50 AD ED 6F 19 76 (firmware constant).
For this device: P1=BD 72 P2=1E 02 P3=13 DE P4=6A 94.
The same masks apply to PROBE_PRESET_SETTING outbound payloads.
GATT:
bbb0 = WRITE (TX) bbb1 = NOTIFY (RX) bbb3 = NOTIFY2 (RX, secondary)
Source bit semantics:
source=DEVICE (bit0=1) → autonomous periodic push (byte5=0xD4)
source=APP (bit0=0) → device response after button press (byte5=0x3D)
import asyncio
import base64
import hashlib
import struct
import sys
import time
import uuid
import builtins
from datetime import datetime
from bleak import BleakClient, BleakError
from cryptography.hazmat.primitives.ciphers import Cipher, algorithms, modes
try:
import readline
except ImportError:
readline = None
_orig_print = builtins.print
def _async_print(*args, **kwargs):
if kwargs.get('file', sys.stdout) in (None, sys.stdout):
sys.stdout.write('\r\x1b[2K')
_orig_print(*args, **kwargs)
if readline:
buf = readline.get_line_buffer()
sys.stdout.write(f"Alarm input> {buf}")
else:
sys.stdout.write("Alarm input> ")
sys.stdout.flush()
else:
builtins.print = _async_print
MAC = "XX:XX:XX:XX:XX:XX"
DEVICE_KEY = "XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX"
NOTIFY_UUID = "0000bbb1-0000-1000-8000-00805f9b34fb"
NOTIFY_UUID2 = "0000bbb3-0000-1000-8000-00805f9b34fb"
WRITE_UUID = "0000bbb0-0000-1000-8000-00805f9b34fb"
POLL_INTERVAL = 3
_AES_KEY = bytes.fromhex(hashlib.md5(DEVICE_KEY.encode()).hexdigest())
_AES_IV = b'0000000000000000'
_XOR_KEY = hashlib.md5(DEVICE_KEY.encode()).digest()
APP_UUID = str(uuid.uuid4())
_tx_tsn = 0
def _next_tsn() -> int:
global _tx_tsn
tsn = _tx_tsn
_tx_tsn = (_tx_tsn + 1) % 256
return tsn
_last_push_probes: list[dict] | None = None
_ticket_queue: asyncio.Queue[int] | None = None
_last_ticket: int | None = None
_last_ticket_mono: float = 0.0
_pending_ticket_responses: dict[int, asyncio.Future[dict]] = {}
_client: BleakClient | None = None
def _aes_encrypt(plaintext: str) -> str:
pad = 16 - (len(plaintext) % 16)
padded = plaintext.encode() + bytes([pad] * pad)
cipher = Cipher(algorithms.AES(_AES_KEY), modes.CBC(_AES_IV))
enc = cipher.encryptor()
return base64.b64encode(enc.update(padded) + enc.finalize()).decode()
def _aes_decrypt(b64: str) -> str:
ct = base64.b64decode(b64)
dec = cipher.decryptor()
raw = dec.update(ct) + dec.finalize()
return raw[:-raw[-1]].decode()
def _xor_crypt(data: bytes) -> bytes:
out = bytearray()
for start in range(0, len(data), 16):
block = data[start:start + 16]
for i, b in enumerate(block):
out.append(b ^ _XOR_KEY[i])
return bytes(out)
class CC:
BATTERY_LEVEL_REQUEST = 257
BATTERY_LEVEL_RESPONSE = 258
PROBE_TEMPERATURE_REQUEST = 259
PROBE_TEMPERATURE_RESPONSE = 260
PROBE_PRESET_SETTING = 261
ALARM_NOTIFY = 262
HISTORY_REQUEST = 263
HISTORY_RESPONSE = 264
CLEAR_HISTORY = 265
TEMPERATURE_CALIBRATION_SETTING = 273
TEMPERATURE_CALIBRATION_REQUEST = 275
TEMPERATURE_CALIBRATION_RESPONSE = 276
ADVANCE_ALARM_REQUEST = 277
ADVANCE_ALARM_RESPONSE = 278
ADVANCE_ALARM_SETTING = 279
TEMPERATURE_UNIT_REQUEST = 281
TEMPERATURE_UNIT_RESPONSE = 282
TEMPERATURE_UNIT_SETTING = 283
CANCEL_ALARM_REQUEST = 284
CANCEL_ALARM_RESPONSE = 285
COMMON_RESPONSE = 65535
_CC_NAMES = {v: k for k, v in vars(CC).items() if not k.startswith('_')}
_PROBE_SENTINELS = {
0xFFFF: 'NOT_ACTIVE',
0xFFFE: 'TOO_HIGH',
0xFFFD: 'TOO_LOW',
0x0FFF: 'INVALID',
_RESP_SECONDARY_KEY = bytes([0x38, 0xA3, 0x50, 0xAD, 0xED, 0x6F, 0x19, 0x76])
_RESP_PROBE_MASKS = [
bytes([_XOR_KEY[2 + i*2] ^ _RESP_SECONDARY_KEY[i*2],
_XOR_KEY[3 + i*2] ^ _RESP_SECONDARY_KEY[i*2 + 1]])
for i in range(4)
def _unmask_resp_payload(payload_content: bytes) -> bytes:
out = bytearray()
for i, mask in enumerate(_RESP_PROBE_MASKS):
ofs = i * 2
if ofs + 1 >= len(payload_content):
break
out.append(payload_content[ofs] ^ mask[0])
out.append(payload_content[ofs + 1] ^ mask[1])
return bytes(out)
NO_ALARM = 0x0100
_alarm_targets: list[int | None] = [None, None, None, None]
PRESET_EMPTY = 0
PRESET_UPPER_TEMP = 1
PRESET_RANGE = 2
WIRE_PROBE_INDEX_BASE = 0
def _build_preset_payload(targets: list[int | None]) -> bytes:
probe = bytearray()
for i in range(4):
t = NO_ALARM if (i >= len(targets) or targets[i] is None) else int(targets[i])
lo, hi = t & 0xFF, (t >> 8) & 0xFF
probe.append(lo ^ _RESP_PROBE_MASKS[i][0])
probe.append(hi ^ _RESP_PROBE_MASKS[i][1])
x0 = 0xDA
for b in probe:
x0 ^= b
return bytes(probe) + bytes([x0, 0x1E, 0x60, 0xA8])
def _le16(value: int) -> bytes:
return struct.pack('<H', int(value) & 0xFFFF)
def _build_upper_alarm_payload(probe: int, temp_c: int | None, timer_ms: int = 0) -> bytes:
wire_probe = probe - 1 + WIRE_PROBE_INDEX_BASE
if temp_c is None:
preset_type = PRESET_EMPTY
lower_c = lower_f = upper_c = upper_f = NO_ALARM
else:
preset_type = PRESET_UPPER_TEMP
upper_c = int(temp_c)
upper_f = round(upper_c * 9 / 5 + 32)
lower_c = upper_c
lower_f = upper_f
timer_seconds = int(timer_ms / 1000)
return (
bytes([wire_probe, preset_type])
+ _le16(lower_c)
+ _le16(lower_f)
+ _le16(upper_c)
+ _le16(upper_f)
+ _le16(timer_seconds)
+ bytes([int(timer_ms) & 0xFF])
def _build_captured_alarm_payload(temp_c: int | None) -> bytes:
if temp_c is None:
values = [NO_ALARM, NO_ALARM, NO_ALARM, NO_ALARM]
else:
temp_f = round(temp_c * 9 / 5 + 32)
values = [NO_ALARM, int(temp_c), int(temp_f), int(temp_c)]
return _build_preset_payload(values)
async def set_probe_alarm(probe: int, temp_c: int | None):
if not (1 <= probe <= 4):
raise ValueError(f"probe must be 1-4, got {probe}")
if temp_c is not None and not (20 <= temp_c <= 82):
raise ValueError(f"temp_c must be 20-82 C, got {temp_c}")
_alarm_targets[probe - 1] = temp_c
payload = _build_upper_alarm_payload(probe, temp_c)
try:
response = await _send_outputjs_alarm_control(payload, timeout=7.0)
except TimeoutError as e:
print(f"ALARM: {e} — command was sent but no ACK arrived")
return
label = f"{temp_c}°C" if temp_c is not None else "disabled"
if response.get('command') != CC.COMMON_RESPONSE:
name = response.get('name', f"0x{response.get('command', 0):04X}")
print(f"ALARM P{probe}: unexpected response {name}; not marking as set")
return
status = response.get('status')
if status == 0:
print(f"ALARM SET P{probe}: {label}")
else:
print(f"ALARM P{probe}: {label} rejected, response status={status}")
def _extract_control_message(data: bytes) -> dict | None:
if len(data) < 4:
return None
command = struct.unpack_from('<H', data, 0)[0]
data_length = struct.unpack_from('<H', data, 2)[0]
decrypted = _xor_crypt(data[4:])
if data_length != len(decrypted):
print(f"[WARN] control frame length mismatch: expected={data_length} got={len(decrypted)}")
return None
flags = decrypted[0]
source = flags & 0x01
need_response = (flags >> 1) & 0x01
rx_tsn = decrypted[1]
payload_content = bytes(decrypted[2:])
return {
'command': command,
'name': _CC_NAMES.get(command, f'0x{command:04X}'),
'source': source,
'need_response': need_response,
'rx_tsn': rx_tsn,
'payload_content': payload_content,
def _decode_probe(raw: int) -> dict:
sentinel = _PROBE_SENTINELS.get(raw)
if sentinel:
return {'status': sentinel, 'temp_c': None, 'temp_f': None,
'raw': f'0x{raw:04X}'}
temp_c = float(raw)
temp_f = round(temp_c * 9 / 5 + 32, 1)
return {'status': 'ok', 'temp_c': temp_c, 'temp_f': temp_f,
def _parse_probe_temperatures(payload_content: bytes) -> list[dict]:
probes = []
for i in range(0, len(payload_content) - 1, 2):
raw = struct.unpack_from('<H', payload_content, i)[0]
probes.append(_decode_probe(raw))
return probes
def _build_control_frame(command: int, need_response: bool = True,
payload_content: bytes = b'',
token_tsn: int | None = None) -> bytes:
flags = (0 << 0) | ((1 if need_response else 0) << 1)
tx_tsn = token_tsn if token_tsn is not None else _next_tsn()
raw_payload = bytes([flags, tx_tsn]) + payload_content
encrypted = _xor_crypt(raw_payload)
return struct.pack('<HH', command, len(encrypted)) + encrypted
def _build_ticketed_frame(command: int, ticket: int, payload_content: bytes = b'') -> bytes:
raw_payload = bytes([0x89, ticket]) + payload_content
return struct.pack('<HH', command, len(raw_payload)) + raw_payload
def _build_captured_alarm_frame(ticket: int, payload_content: bytes) -> bytes:
raw_payload = bytes([0xEB, ticket ^ _XOR_KEY[1]]) + payload_content
return struct.pack('<HH', CC.PROBE_PRESET_SETTING, len(encrypted)) + encrypted
def _build_outputjs_alarm_frame(ticket: int, payload_content: bytes) -> tuple[bytes, int]:
token_tsn = ticket ^ _XOR_KEY[1]
frame = _build_control_frame(
need_response=True,
payload_content=payload_content,
token_tsn=token_tsn,
return frame, token_tsn
def _live_ticket_marker(data: bytes) -> int | None:
if len(data) >= 6 and data[:4] == b'\x04\x01\x0A\x00' and data[4] in (0x82, 0xD4):
return data[4]
return None
def _offer_ticket(ticket: int):
global _last_ticket, _last_ticket_mono
_last_ticket = ticket
_last_ticket_mono = time.monotonic()
if _ticket_queue is None:
return
try:
_ticket_queue.put_nowait(ticket)
except asyncio.QueueFull:
try:
_ticket_queue.get_nowait()
except asyncio.QueueEmpty:
pass
async def _next_ticket(timeout: float = 5.0) -> int:
raise TimeoutError("ticket queue is not ready")
try:
return await asyncio.wait_for(_ticket_queue.get(), timeout=timeout)
except asyncio.TimeoutError as e:
raise TimeoutError("timeout waiting for fresh live telemetry ticket") from e
def _parse_raw_ticket_response(data: bytes) -> dict | None:
if len(data) < 6 or data[4] != 0x8E:
return None
payload = data[4:]
if data_length != len(payload):
print(f"[WARN] raw frame length mismatch: expected={data_length} got={len(payload)}")
return None
content = bytes(payload[2:])
msg = {
'command': command,
'marker': payload[0],
'ticket': payload[1],
'payload_content': content,
'status': None,
if command == CC.COMMON_RESPONSE and len(content) >= 2:
msg['status'] = struct.unpack_from('<H', content, 0)[0]
return msg
def _finish_pending_response(ticket: int, msg: dict):
future = _pending_ticket_responses.get(ticket)
if future and not future.done():
future.set_result(msg)
async def _send_ticketed_control(command: int, payload_content: bytes = b'',
timeout: float = 5.0) -> dict:
ticket = await _next_ticket(timeout=timeout)
frame = _build_ticketed_frame(command, ticket, payload_content)
loop = asyncio.get_running_loop()
response_future: asyncio.Future[dict] = loop.create_future()
_pending_ticket_responses[ticket] = response_future
print(f"TX ticket=0x{ticket:02X}: {_fmt_hex(frame)}")
try:
await _ble_write(frame)
try:
return await asyncio.wait_for(response_future, timeout=timeout)
raise TimeoutError(f"timeout waiting for response to ticket 0x{ticket:02X}") from e
finally:
_pending_ticket_responses.pop(ticket, None)
async def _send_captured_alarm_control(payload_content: bytes,
frame = _build_captured_alarm_frame(ticket, payload_content)
print(f"TX captured-alarm ticket=0x{ticket:02X}: {_fmt_hex(frame)}")
try:
try:
finally:
async def _send_outputjs_alarm_control(payload_content: bytes,
frame, token_tsn = _build_outputjs_alarm_frame(ticket, payload_content)
_pending_ticket_responses[token_tsn] = response_future
print(f"TX outputjs-alarm ticket=0x{ticket:02X} tsn=0x{token_tsn:02X}: {_fmt_hex(frame)}")
try:
try:
raise TimeoutError(f"timeout waiting for COMMON_RESPONSE to ticket 0x{ticket:02X}") from e
finally:
_pending_ticket_responses.pop(token_tsn, None)
async def _ble_write(data: bytes):
for i in range(0, len(data), 20):
await _client.write_gatt_char(WRITE_UUID, data[i:i + 20], response=False)
await asyncio.sleep(0.05)
async def _send_auth_frame(msg_type: int, body: bytes):
header = bytes([msg_type, 0x00]) + struct.pack('<H', len(body))
await _ble_write(header + body)
async def _send_control(command: int, need_response: bool = True,
payload_content: bytes = b''):
if need_response:
await _send_ticketed_control(command, payload_content)
return
frame = _build_control_frame(command, need_response, payload_content)
def _fmt_hex(data: bytes) -> str:
return ' '.join(
f'\033[32m{b:02X}\033[0m' if i < 4 else f'{b:02X}'
for i, b in enumerate(data)
def _fmt_probe(p: dict, label: str) -> str:
if p['status'] != 'ok':
return f"{label}={p['status']}"
return f"{label}={p['temp_c']:.0f}°C({p['temp_f']:.1f}°F)"
def _print_temps(probes: list[dict], tag: str, tsn: int):
now = datetime.now().strftime('%H:%M:%S')
probe_str = ' '.join(_fmt_probe(p, f'P{i+1}') for i, p in enumerate(probes))
print(f"TEMP [{now}] {tag} tsn={tsn:3d} {probe_str}")
def _handle_raw_v5_packet(data: bytes) -> bool:
global _last_push_probes
marker = _live_ticket_marker(data)
if marker is not None:
ticket = data[5]
_offer_ticket(ticket)
print(f"TICKET fresh: marker=0x{marker:02X} ticket=0x{ticket:02X}")
if marker == 0xD4:
return False
probes = _parse_probe_temperatures(data[6:])
_last_push_probes = probes
_print_temps(probes, 'PUSH', ticket)
return True
raw_response = _parse_raw_ticket_response(data)
if raw_response is None:
return False
ticket = raw_response['ticket']
_finish_pending_response(ticket, raw_response)
cmd = raw_response['command']
payload = raw_response['payload_content']
if cmd == CC.BATTERY_LEVEL_RESPONSE:
level = payload[0] if payload else '?'
print(f"BATTERY [RAW] ticket=0x{ticket:02X}: {level}%")
elif cmd == CC.PROBE_TEMPERATURE_RESPONSE:
probes = _parse_probe_temperatures(payload)
_print_temps(probes, 'RESP', ticket)
elif cmd == CC.TEMPERATURE_UNIT_RESPONSE:
unit = 'Fahrenheit' if payload and payload[0] else 'Celsius'
print(f"TEMP_UNIT [RAW] ticket=0x{ticket:02X}: {unit}")
elif cmd == CC.COMMON_RESPONSE:
print(f"COMMON_RESPONSE [RAW] ticket=0x{ticket:02X}: status={raw_response['status']}")
else:
print(f"CONTROL [RAW] [{raw_response['name']}] ticket=0x{ticket:02X} "
f"payload={payload.hex().upper()}")
return True
async def _on_notify(sender, data: bytes):
print(f"RX: {_fmt_hex(data)}")
if len(data) < 2:
return
if _handle_raw_v5_packet(data):
return
is_control = (data[1] == 0x01) or (data[0] == 0xFF and data[1] == 0xFF)
if is_control:
msg = _extract_control_message(data)
if msg is None:
return
cmd = msg['command']
is_push = msg['source'] == 1
src = 'PUSH' if is_push else 'RESP'
if is_push:
probes = _parse_probe_temperatures(msg['payload_content'])
_print_temps(probes, 'PUSH', msg['rx_tsn'])
else:
unmasked = _unmask_resp_payload(msg['payload_content'])
probes = _parse_probe_temperatures(unmasked)
_print_temps(probes, 'RESP', msg['rx_tsn'])
elif cmd == CC.BATTERY_LEVEL_RESPONSE:
level = msg['payload_content'][0] if msg['payload_content'] else '?'
print(f"BATTERY [{src}]: {level}%")
unit = 'Fahrenheit' if (msg['payload_content'] and msg['payload_content'][0]) else 'Celsius'
print(f"TEMP_UNIT [{src}]: {unit}")
if len(msg['payload_content']) >= 2:
status = struct.unpack_from('<H', msg['payload_content'])[0]
else:
status = '?'
msg['status'] = status
_finish_pending_response(msg['rx_tsn'], msg)
_finish_pending_response(msg['rx_tsn'] ^ _XOR_KEY[1], msg)
print(f"COMMON_RESPONSE [{src}]: status={status}")
else:
print(f"CONTROL [{src}] [{msg['name']}] tsn={msg['rx_tsn']} "
f"payload={msg['payload_content'].hex().upper()}")
return
cmd = data[0]
if cmd == 0x01 and data[1] == 0x00:
try:
body = data[4:].decode('ascii', errors='ignore').strip('\x00')
device_uuid = _aes_decrypt(body)
confirm = _aes_encrypt(f"{APP_UUID}_{device_uuid}").encode()
await _send_auth_frame(0x02, confirm)
print("AUTH: challenge response sent")
except Exception as e:
print(f"AUTH error: {e}")
return
if cmd == 0x03:
print("AUTH: accepted")
await _client.write_gatt_char(WRITE_UUID, bytes([0x21, 0x00, 0x00, 0x00]),
response=False)
asyncio.create_task(_initial_probe_request())
return
if cmd in (0x1D, 0x22):
return
print(f"UNKNOWN cmd=0x{cmd:02X} data={data.hex().upper()}")
async def _on_notify2(sender, data: bytes):
print(f"RX2: {_fmt_hex(data)}")
async def _poll_loop():
while True:
await asyncio.sleep(POLL_INTERVAL)
if _client and _client.is_connected:
if time.monotonic() - _last_ticket_mono < POLL_INTERVAL * 2:
continue
try:
await _send_control(CC.PROBE_TEMPERATURE_REQUEST, need_response=True)
print(f"Probe temperature request skipped: {e}")
async def _initial_probe_request():
await asyncio.sleep(0.5)
try:
print("Probe temperature requested\n")
print(f"Initial probe temperature request skipped: {e}\n")
async def _input_loop():
loop = asyncio.get_event_loop()
print("Alarm input: <temp 20-82> for probe 1, or <probe:temp>, or <probe:off>")
while True:
try:
line = await loop.run_in_executor(None, input, "Alarm input> ")
except Exception:
break
line = line.strip()
if not line:
continue
try:
if ':' in line:
p_str, t_str = line.split(':', 1)
probe = int(p_str.strip())
t_str = t_str.strip()
else:
probe = 1
t_str = line.strip()
if t_str.lower() == 'off':
temp = None
else:
temp = int(t_str)
if not (20 <= temp <= 82):
print(f"Temperature must be 20-82°C (got {temp})")
continue
except ValueError:
print("Usage: <temp> or <probe:temp> or <probe:off>")
continue
await set_probe_alarm(probe, temp)
else:
label = f"{temp}°C" if temp is not None else "disabled"
print(f"ALARM P{probe} queued: {label} (not connected yet)")
async def main():
global _client, _tx_tsn, _last_push_probes, _ticket_queue, _last_ticket
print(f"BMT01 version 2026-05-03 rev B — connecting to {MAC}")
print(f"XOR key (MD5 raw bytes): {_XOR_KEY.hex()}\n")
_ticket_queue = asyncio.Queue(maxsize=1)
input_task = asyncio.create_task(_input_loop())
while True:
_tx_tsn = 0
_last_push_probes = None
_last_ticket = None
_pending_ticket_responses.clear()
while _ticket_queue is not None:
try:
break
try:
async with BleakClient(MAC, timeout=20) as client:
_client = client
print("Connected")
await client.start_notify(NOTIFY_UUID, _on_notify)
try:
await client.start_notify(NOTIFY_UUID2, _on_notify2)
print("bbb3 subscribed")
except Exception:
pass
await _send_auth_frame(0x00, _aes_encrypt(APP_UUID).encode())
print("AUTH: request sent\n")
poll_task = asyncio.create_task(_poll_loop())
try:
while client.is_connected:
await asyncio.sleep(1)
finally:
poll_task.cancel()
print("Disconnected — reconnecting in 3 s...")
await asyncio.sleep(3)
except BleakError as e:
print(f"BLE error: {e} — retry in 5 s...")
await asyncio.sleep(5)
except KeyboardInterrupt:
input_task.cancel()
print("\nStopped.")
return
if __name__ == "__main__":
asyncio.run(main())
