Everything with my home assistant was working up until a few months ago and now since changes in the UI I have loads of issues with my configuration.
1 issue I have is automations to turn bulbs on when motion is detected trigger when the bulb is already on, causing it to flash - even though I have a condition for if the bulb is off.
Another issue is bulbs that are on report as off and when I try to change the state, I get an error object has no attribute color_temp.
Would love some help with this as I have tried loads of things to try to fix. I have deleted from HA and reimported from Sonoff, I have deleted the entity from the dashboard and readded it.
These issues ‘sound’ to me like automation issues.
Could you share some of the automations or scripts that you are using when these bulbs do these behaviors?
Color_temp function has recently completed a 6 month deprecation and is no longer a function, for instance, replaced by color_temp_kelvin. color_temp_deprecation
Please show us YAML code formatted with the </> button here in the editor so we can help you properly.
