Sonoff Dongle Added as a Light Switch??
I have installed a sonoff dongle e to HA using ZHA and it shows up as a light switch. Ive flashed it in router mode since i have a SLZB-06M as coordinator. Is this normal?
If your old dongle is showing up as a zigbee router & actually routing your zigbee mesh, you should probably stop caring.
I can almost guarantee that you’ll forget it shows up as a light in a month’s time
There is an LED on it you can also control…
ok yes seems to be working fine. just thought i missed something when i installed it. So if i were to shut off the light toggle in HA it would still work?
