Sonoff Dongle-M Zig2MQTT CRC error
I have run into this issue today. It happened after I added a couple of Aqara Curtain Drivers. I have tried going back to 1.0.5, switching back to 1.0.7 and even installing 1.0.9-beta
Any other suggestions for things I could try.
I have done a factory reset but to no avail.
Hi Guys,
Thought I'd share an update, there seems to be a newer version out
V1.0.10 Release Notes: 1) Support more AP configuration options: Hide SSID, IPv4 Address, Operating Frequency; 2) Support more Notification message types and deleting all messages; 3) UART over TCP connection stability has been significantly improved; 4) Add support for modifying AP SSID; 5) Add support for modifying Hostname which also modifies mDNS name; 6) When multiple routers use the same SSID, connect to the one with the strongest signal; 7) Bug fix: WireGuard Endpoint doesn't work with domain name. 8) Bug fix: Static IP automatically changes to Smart IP after reboot when Static IP is not within the IP range of the DHCP service; 9) Some other minor improvements.
I think the TCP improvements it mentions fixes this issue we are seeing. I flashed with no issues now.
  1. Shut down Z2M
  2. Flash firmware to dongle-m
  3. Unplug dongle-m, wait 1 min and replug
  4. Once Dongle-M is running, restart Z2M
Worked fine, not seeing any issues thus far :slight_smile:
