I still consider myself fairly new to this (not by when I started with it, but by what I comprehend about it).
I flashed the latest coordinator firmware to the MG. I flashed the latest router software to the Sonoff E stick. Both using the sonoff flasher on the web: Sonoff Dongle Flasher - SONOFF Dongle.
Installed zigbee2mqtt (z2m for shortening it). Coordinator seems to work, sees my aqara stuff, the sonoff water valve in the garden, the IKEA LED repeater tc.
It seems not to see the Sonoff E I flashed as a router.
a) where would I see the E stick if all went well? As a normal device in z2m devices page?
b) why does it not work?
PS: Back when the E stick was the sole coordinator with ZHA, it saw even my small tiny USB repeaters (noname things from aliexpress. Those are not seen by the current Z2M setup, either)
PS2: Little sidenote, the silabs github darkxst etc flashed does not work .. it just hangs in "detecting firmware".
PS3: Why is the Z2M network map only showing the connections to the IKEA LED repeater? All otehr deices on the MG24 do work, but are just dots and no coordinator in the image.
