Sonoff iFan03 with ESPHome: The Definitive Guide (Fixes Low Speed Stalling + Silent Mode)
Hi everyone,
UPDATE (18 January): I have significantly updated the configuration to make it more robust and reliable.
Like many of you, I struggled with the Sonoff iFan03 on ESPHome. The main issues were the fan stalling/humming on “Low” speed (due to motor inertia) and the annoying buzzer.
I analyzed the hardware behavior and created a robust configuration that solves these issues completely.
Key Improvements:
  1. RF Reliability (Debounce): [NEW] Implemented a 300ms software debounce. This prevents the common issue where 433MHz remotes send multiple codes per press, fixing “stuttering” buzzer sounds or unintended rapid toggling of the light.
  2. Kickstart Logic (Boost): When turning on to Low or Medium, the fan momentarily powers HIGH (4s) to overcome friction, then drops to the target speed. No more humming motors!
  3. Safety Stop: It turns off all relays for 500ms before switching speeds to prevent arcing.
  4. Silent Mode: Added a simple option to disable the buzzer completely.
  5. Feedback: If the buzzer is on, it gives feedback even when controlled via Home Assistant (not just the remote).
:inbox_tray: Download & Documentation
This configuration is now officially part of the ESPHome Devices Repository!
You can find the documentation and the latest clean YAML code here:
:backhand_index_pointing_right: Official Page: Sonoff iFan03 on ESPHome-Devices
(If you want to see the development history or contribute, check the GitHub repository)
:gear: YAML Configuration (Quick Copy)
For those who want to try it right now, here is the full configuration.
substitutions:
  friendly_name: "Living Room Fan"
  comment: "Sonoff Ifan03 Fan Controller (ESP8285)"
  api_key: ""
  ota_password: ""
  wifi_ssid: !secret wifi_ssid
  wifi_password: !secret wifi_password
  on_boot_light: ALWAYS_OFF # or ALWAYS_ON
  buzzer_enabled: "true"
globals:
  - id: last_speed
    type: int
    restore_value: no
    initial_value: '0'   # 0=OFF, 1=LOW, 2=MED, 3=HIGH
  - id: target_speed
    type: int
    restore_value: no
    initial_value: '0'
  - id: last_rf_ms
      type: uint32_t
      restore_value: no
      initial_value: '0'
esphome:
  comment: $comment
  friendly_name: $friendly_name
  on_boot:
    priority: -100
    then:
      - switch.turn_off: fan_relay1
      - switch.turn_off: fan_relay2
      - switch.turn_off: fan_relay3
      - lambda: |-
          id(last_speed) = 0;
          id(target_speed) = 0;
esp8266:
  board: esp8285
api:
  encryption:
    key: $api_key
ota:
  - platform: esphome
    password: $ota_password
wifi:
  ssid: $wifi_ssid
  password: $wifi_password
  min_auth_mode: WPA2
  ap:
    ssid: "$name AP"
captive_portal:
logger:
  level: INFO
  baud_rate: 0
  logs:
    remote_receiver: WARN
  - platform: wifi_signal
    update_interval: 60s
    entity_category: diagnostic
button:
  - platform: restart
    on_press:
      - switch.turn_on: buzzer_switch
      - delay: 50ms
      - switch.turn_off: buzzer_switch
text_sensor:
  - platform: uptime
  - platform: version
    hide_timestamp: true
  - platform: wifi_info
    ip_address:
output:
  - platform: gpio
    pin: GPIO9
    inverted: true
switch:
  - platform: gpio
    internal: True
    pin:
      number: GPIO10
      inverted: true
  - platform: gpio
    internal: true
    pin: GPIO14
    restore_mode: ALWAYS_OFF
  - platform: gpio
    internal: true
    pin: GPIO12
  - platform: gpio
    internal: true
    pin: GPIO15
light:
  - platform: binary
    output: light_relay
    restore_mode: $on_boot_light
    on_state:
      then:
        - script.execute: beep_feedback
script:
  - id: fan_set_speed
    mode: restart
    then:
      # 1. Turn off if it was on
      - if:
          condition:
            lambda: 'return id(last_speed) != 0;'
          then:
            - delay: 500ms
      # 2. BOOST only from OFF to LOW or MED
      - if:
          condition:
            lambda: |-
              return id(last_speed) == 0 &&
                     (id(target_speed) == 1 || id(target_speed) == 2);
          then:
            - switch.turn_on: fan_relay3
            - delay: 4s
            - delay: 500ms
      # 3. Set final velocity
      - if:
          condition:
            lambda: 'return id(target_speed) == 1;'
          then:
            - switch.turn_on: fan_relay1
      - if:
          condition:
            lambda: 'return id(target_speed) == 2;'
          then:
            - switch.turn_on: fan_relay2
      - if:
          condition:
            lambda: 'return id(target_speed) == 3;'
          then:
      # 4. Store real state
      - lambda: |-
          id(last_speed) = id(target_speed);
  - id: beep_feedback
    mode: restart
    then:
      - if:
          condition:
            lambda: 'return ${buzzer_enabled};'
          then:
            - button.press: buzzer
  - id: rf_gate
    mode: single
    parameters:
      action: int
    then:
      - lambda: |-
          uint32_t now = millis();
          if (now - id(last_rf_ms) < 300) {
            return;
          id(last_rf_ms) = now;
          switch (action) {
            case 0: {
              auto call = id(ifan03_fan).turn_off();
              call.perform();
              break;
            case 1: {
              auto call = id(ifan03_fan).turn_on();
              call.set_speed(1);
              call.perform();
              break;
            case 2: {
              call.set_speed(2);
              call.perform();
              break;
            case 3: {
              call.set_speed(3);
              call.perform();
              break;
            case 4: {
              auto call = id(ifan03_light).toggle();
              call.perform();
              break;
            case 5: {
              id(buzzer).press();
              break;
fan:
    speed_count: 3
    restore_mode: NO_RESTORE # important
    on_turn_on:
      - lambda: |-
          // If for any reason the speed is 0, we force 1 (Low).
          if (id(ifan03_fan).speed == 0) {
            id(target_speed) = 1;
          } else {
            // If you already have speed, we use it.
            id(target_speed) = id(ifan03_fan).speed;
      - script.execute: fan_set_speed
    on_turn_off:
      - lambda: |-
    on_speed_set:
      - lambda: |-
remote_receiver:
  pin: GPIO3
binary_sensor:
  # remote button row 3 button 1
  - platform: remote_receiver
    raw:
      code: [-207, 104, -103, 104, -104, 103, -104, 207, -104, 103, -104, 104,
             -103, 104, -104, 103, -104, 105, -102, 104, -725, 104, -311, 103,
             -518, 104, -933, 103, -104, 104, -725, 104, -932, 104, -207, 207, -519]
    on_release:
      - script.execute:
          action: 0
    internal: true
  # remote button row 3 button 2
    raw:
      code: [-207, 104, -104, 103, -104, 104, -103, 207, -104, 104, -103, 104,
             -104, 103, -104, 104, -103, 104, -104, 103, -726, 103, -312, 103,
             -518, 104, -933, 103, -104, 104, -725, 104, -103, 104, -726, 103,
             -104, 311, -518]
    on_release:
      - script.execute:
          action: 1
    internal: true
  # remote button row 2 button 2
    raw:
      code: [-208, 103, -104, 104, -103, 104, -103, 208, -103, 104, -104, 103,
             -104, 104, -103, 104, -104, 103, -104, 103, -726, 104, -310, 104,
             -518, 104, -933, 103, -104, 104, -725, 104, -207, 104, -622, 103,
             -416, 102, -415]
    on_release:
      - script.execute:
          action: 2
    internal: true
  # remote button row 2 button 1
    raw:
      code: [-207, 104, -104, 103, -104, 104, -103, 208, -103, 104, -104, 103,
             -104, 104, -103, 104, -104, 103, -104, 103, -726, 104, -311, 104,
             -518, 103, -934, 103, -103, 104, -726, 103, -104, 207, -622, 104,
             -103, 104, -207, 104, -415]
    on_release:
      - script.execute:
          action: 3
    internal: true
  # remote button row 1 button 1
    raw:
             -103, 104, -103, 104, -104, 103, -104, 104, -725, 104, -311, 103,
             -518, 104, -933, 103, -104, 103, -726, 103, -311, 104, -518, 104,
             -207, 104, -103, 104, -414]
    on_release:
      - script.execute:
          action: 4
    internal: true
  # remote button row 1 button 2
    filters:
          - delayed_off: 200ms
    raw:
      code: [-207, 104, -103, 104, -104, 103, -104, 207, -104, 103, -104, 103,
             -104, 104, -103, 104, -103, 104, -104, 107, -721, 105, -206, 207,
             -518, 105, -931, 104, -104, 103, -725, 104, -104, 103, -725, 104,
             -104, 103, -207, 104, -414]
    on_release:
      - script.execute:
          action: 5
Credits
I want to thank everyone who worked on this device before. This configuration builds upon the ideas and testing done by the community in previous threads. I took those foundations as inspiration and refined the logic to create this stable version.
I assume this will also work with the US version of the iFan04?
This is what I’m currently using for the iFan04 in the US:
It could be updated and included in the ESPHome device repository.
Hi! Sorry for the delay, I completely missed your comment until now.
Yes, it should work with the US version of the iFan04. From a hardware perspective, the architecture is virtually identical to the iFan03. They both share the same ESP8285 chip and the exact same pinout (GPIO12, 14, 15 for the fan relays; GPIO9 for the light; GPIO10 for the buzzer). The main differences in the iFan04 US are the internal capacitors (spec’d for 110V to maintain correct speeds) and a revised RF antenna.
Since my configuration already uses board: esp8285 under the esp8266 component, it should compile fine and the safety logic (the 500ms break-before-make delay and the 4-second startup boost) should port over perfectly.
Give it a shot and let me know how it goes!
