Sonoff ifan4 seen by HA/ESP but can't connect
I installed HAos to a new machine after the previous one went down. I did not have a backup off of the other machine and other issues that made it impossible to get my previous setup. So I’ve started from scratch, which has actually been nice except for ESPHome and these ifans.
I had them working before and they were receiving OTA updates and most things were working through the HA frontend. I have the ifans on a different vlan and that setup hasn’t changed, still works for other devices.
HA sees the ESPHome ifans and asks to add them. However when I try it errors and says an API needs to be on the yaml. I have reviewed the config in ESPHome for the ifans and its there. I’m not sure what I’m missing or if I have to start from scratch with the flashing process.
Thanks for your help and feedback.
What do the esphome logs say?
What is your yaml?
Log for attempting to install the yaml to the iFan04:
INFO Reading configuration /config/esphome/office-fan.yaml...
INFO Detected timezone 'America/New_York'
WARNING ESP8266: Pin 9 (9-10) might already be used by the flash interface in QUAD IO flash mode.
WARNING ESP8266: Pin 10 (9-10) might already be used by the flash interface in QUAD IO flash mode.
INFO Generating C++ source...
INFO Compiling app...
Processing office-fan (board: esp01_1m; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- <ESPAsyncTCP-esphome> 1.2.3
|-- <ESPAsyncWebServer-esphome> 2.1.0
|   |-- <Hash> 1.0
|   |-- <ESP8266WiFi> 1.0
|-- <DNSServer> 1.1.1
|-- <ESP8266mDNS> 1.2
|-- <noise-c> 0.1.4
|   |-- <libsodium> 1.10018.1
RAM:   [====      ]  43.1% (used 35340 bytes from 81920 bytes)
Flash: [=====     ]  53.5% (used 547521 bytes from 1023984 bytes)
========================= [SUCCESS] Took 11.95 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of office-fan.local
INFO  -> 192.168.50.19
ERROR Connecting to office-fan.local:8266 failed: timed out
yaml for same iFan:
substitutions:
  device_description: Sonoff iFan04-L
  friendly_name: Office Fan/Light
globals:
  - id: target_fan_speed
    type: int
  - id: start_time_offset
    type: int
esphome:
  comment: ${device_description}
  platform: ESP8266
  board: esp01_1m
  on_boot:
    priority: 225
    # turn off the light as early as possible
    then:
      - light.turn_off: fan_light
  on_loop:
    lambda: |-
      if (id(start_time_offset) && (millis() > id(start_time_offset))) {
        ESP_LOGD("IFAN04", "Setting target speed: %d", id(target_fan_speed));
        auto call = id(the_fan).turn_on();
        call.set_speed(id(target_fan_speed));
        call.perform();
        id(start_time_offset) = 0;
# Enable logging
logger:
  baud_rate: 0
# Enable Home Assistant API
api:
  encryption:
    key: "REDACTED"
  port: 6053
ota:
  password: "REDACTED"
wifi:
  ssid: !secret wifi_ssid
# web_server:
#  port: 80
#  auth:
#    username: !secret web_server_username
#    password: !secret web_server_password
  ap:
    ssid: "Office-Fan Fallback Hotspot"
external_components:
  - source: github://ssieb/custom_components
    components: [ ifan04 ]
time:
  - platform: homeassistant
    on_time_sync:
      - component.update: sensor_uptime_timestamp
uart:
  tx_pin: GPIO01
  rx_pin: GPIO03
  baud_rate: 9600
#  debug:
#    sequence:
#      - lambda: UARTDebug::log_hex(direction, bytes, ',');
ifan04:
  on_fan:
    - lambda: |-
        if (speed) {
          call.set_speed(speed);
          call.perform();
          if (id(buzzer_dummy).state) {
            switch(id(target_fan_speed)) {
              case 3:
                id(buzzer_pin).turn_on();
                delay(50);
                id(buzzer_pin).turn_off();
                delay(50);
              case 2:
                delay(50);
                delay(50);
              case 1:
                delay(50);
        } else {
          id(target_fan_speed) = 0;
          auto call = id(the_fan).turn_off();
          call.perform();
  on_light:
    - light.toggle: fan_light
  on_buzzer:
    - switch.toggle: buzzer_dummy
  - platform: uptime
    device_class: "timestamp"
    accuracy_decimals: 0
    update_interval: never
    lambda: |-
      static float timestamp = (
        id(time_homeassistant).utcnow().timestamp - id(sensor_uptime).state
      return timestamp;
  - platform: wifi_signal
    update_interval: 60s
binary_sensor:
  - platform: gpio
    pin: GPIO0
    on_press:
      then:
interval:
  - interval: 500ms
    then:
      - if:
          condition:
            not:
              wifi.connected:
          then:
            - light.turn_on:
                brightness: 100%
                transition_length: 0s
            - delay: 250ms
            - light.turn_off:
                transition_length: 250ms
output:
    type: float
    write_action:
      - lambda: |-
          if (state) {
            int speed = int(state / 0.33);
            if (!id(target_fan_speed) && (speed < 3)) {
              ESP_LOGD("IFAN04", "Fan currently off, boosting speed");
              id(target_fan_speed) = speed;
              state = 1.0;
              id(start_time_offset) = millis() + 5000; // 5 second delay
            } else {
          if (state < 0.3) {
            // OFF
            id(fan_relay1).turn_off();
            id(fan_relay2).turn_off();
            id(fan_relay3).turn_off();
          } else if (state < 0.6) {
            // low speed
            id(fan_relay1).turn_on();
          } else if (state < 0.9) {
            // medium speed
            id(fan_relay2).turn_on();
          } else {
            // high speed
            id(fan_relay3).turn_on();
  - platform: gpio
    pin: GPIO9
    inverted: true
  - platform: gpio
    pin: GPIO10
    inverted: true
  - platform: esp8266_pwm
    pin: GPIO13
    inverted: true
light:
  - platform: binary
    output: light_relay
  - platform: monochromatic
    output: led_pin
    default_transition_length: 0s
    restore_mode: always off
switch:
  - platform: restart
    optimistic: True
  - platform: gpio
    pin: GPIO14
  - platform: gpio
    pin: GPIO12
  - platform: gpio
    pin: GPIO15
fan:
  - platform: speed
    output: fanoutput
    speed_count: 3
captive_portal:
Seems pretty clear. :slight_smile: Your HA instance (in this case the ESPHome addOn) can’t reach the Sonoff.
Did you check the IP address of this specific device in your router? I’d try to reach the device with its local IP address, maybe something with mDNS isn’t working as it should. I read a lot of DNS problems (not specific to your problem or ESPHome) in the last weeks, so to rule this out…
And if this doesn’t work, I’d try to disable mDNS in ESPHome (in the yaml file for this device) and set a fixed IP address in the router and in your ESP file.
