Good day.
I would like to bother with the question:
In the bathroom I have a switch that controls the fan. My plan now is to replace the switch with a button, add a sonoff mini and connect terminals S1 and S2 to the button.
For the mini Sonoff on Tasmota I chose the general module,
D3 GPIO0 Button1 - switch1 (9)
D2 GPIO4 - Button1 (17)
D6 GPIO12 Relay1 - Relay1 (21)
D7 GPIO13 Led1i - LED2 (53)
I have no problem with that, Sonoff works as I imagined. However, I would like to set some time after which the relay would turn off after pressing the sonoff mini button.
Can I make such a setting directly in the sonoff mini? Or do I need some automation in HA?
Later I plan to automate in HA based on a humidity sensor.
Thank you in advance for your sincere help.
