I’m looking for a way to either edit a device, or alter the discovery process so that I can force these Sonoff Mini switches to be switches. I setup 4 of them and they were all discovered as switches, but the fifth one is insisting it’s a light.
I’ve deleted and re-added it several times and it comes in as a light every time.
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2022.9.6",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.5",
"docker": true,
"arch": "x86_64",
"timezone": "America/New_York",
"os_name": "Linux",
"os_version": "5.15.67",
"supervisor": "2022.09.1",
"host_os": "Home Assistant OS 9.0",
"docker_version": "20.10.17",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"sonoff": {
"version": "3.1.0",
"requirements": [
"pycryptodome>=3.6.6"
"hacs": {
"version": "1.26.2",
"requirements": [
"aiogithubapi>=22.2.4"
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/zha",
"requirements": [
"bellows==0.33.1",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.79",
"zigpy-deconz==0.18.1",
"zigpy==0.50.3",
"zigpy-xbee==0.15.0",
"zigpy-zigate==0.9.2",
"zigpy-znp==0.8.2"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"dependencies": [
"file_upload"
"after_dependencies": [
"onboarding",
"usb",
"zeroconf"
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 21841,
"manufacturer": "SONOFF",
"model": "01MINIZB",
"name": "SONOFF 01MINIZB",
"quirk_applied": false,
"quirk_class": "zigpy.device.Device",
"manufacturer_code": 4742,
"power_source": "Mains",
"lqi": 255,
"rssi": -75,
"last_seen": "2022-09-25T16:11:07",
"available": true,
"device_type": "Router",
"signature": {
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress|RxOnWhenIdle|MainsPowered|FullFunctionDevice: 142>, manufacturer_code=4742, maximum_buffer_size=80, maximum_incoming_transfer_size=160, server_mask=11264, maximum_outgoing_transfer_size=160, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0100",
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0xfc57"
"out_clusters": [
"0x0019"
"242": {
"profile_id": 41440,
"device_type": "0x0061",
"in_clusters": [],
"out_clusters": [
"0x0021"
"active_coordinator": false,
"entities": [
"entity_id": "button.switch_office_light_identifybutton",
"entity_id": "light.switch_office_light_light",
"neighbors": [],
"endpoint_names": [
"name": "ON_OFF_LIGHT"
"name": "unknown 97 device_type of 0xa1e0 profile id"
"user_given_name": "Switch Office Light",
"device_reg_id": "a80584625661ab0ea5cf6cc20ceb17ec",
"area_id": "office",
"cluster_details": {
"1": {
"device_type": {
"name": "ON_OFF_LIGHT",
"id": 256
"profile_id": 260,
"in_clusters": {
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0004": {
"attribute_name": "manufacturer",
"value": "SONOFF"
"0x0005": {
"attribute_name": "model",
"value": "01MINIZB"
"unsupported_attributes": {}
"0x0003": {
"endpoint_attribute": "identify",
"attributes": {},
"0x0004": {
"endpoint_attribute": "groups",
"attributes": {},
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"0x0006": {
"endpoint_attribute": "on_off",
"attributes": {
"0x0000": {
"attribute_name": "on_off",
"value": 1
"0x4003": {
"attribute_name": "start_up_on_off"
"0xfc57": {
"endpoint_attribute": "manufacturer_specific",
"attributes": {},
"out_clusters": {
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {},
"242": {
"device_type": {
"name": "unknown",
"id": 97
"in_clusters": {},
"out_clusters": {
"0x0021": {
"endpoint_attribute": "green_power",
"attributes": {},
