SONOFF Orb 4-in-1 (SZNB-01M) Zigbee2MQTT
Hi everyone,
I wanted to share a blueprint I created for the Sonoff SNZB-01M (the round “Orb” 4-button switch) specifically for users running Zigbee2MQTT.
Many existing blueprints for this device rely on the old “Action Sensor” (watching for a text state change) or legacy device triggers. However, modern Zigbee2MQTT setups can now expose button presses as native Event Entities in Home Assistant (e.g., event.switch_sonoff_action), which is cleaner and more responsive.
This blueprint maps all 16 possible commands:
  • 4 Buttons (Top Left, Top Right, Bottom Left, Bottom Right)
  • 4 Actions per button (Single, Double, Triple, and Long Press)
Critical Prerequisite: To use this blueprint, you must enable the new event entity feature in your Zigbee2MQTT configuration:
  1. You must be using Zigbee2MQTT and not ZHA.
  2. Open the Zigbee2MQTT addon/interface.
  3. Go to Settings → Home Assistant Integration.
  4. Check the box for experimental_event_entities.
  5. Restart Zigbee2MQTT.
How it works: This blueprint listens to the event entity generated by Zigbee2MQTT. It detects the specific button press by reading the event_type attribute (e.g., single_button_1, double_button_2) that Z2M sends over MQTT.
This script is designed to be robust—you can leave actions blank if you don’t need them, and it won’t cause errors.
I hope this helps anyone else looking for a clean way to handle this switch with the new MQTT event entities!
Very usefull thanks !
Just one problem, when you assign an action to one button and save it, you have to reload the page to be able to assign and an other action .
This works! Awesome. Thank you.
Thank you for the blueprint! It works very well.
I just had one issue. When there are network issues, I get “ghost” button presses for all my buttons in the house. I suspect it’s because the state of the buttons was temporarily “unavailable”, and the change in state is triggering them. I’m not sure, but I’ve changed the code from
- platform: state
  entity_id: !input sonoff_event_entity
to
- platform: state
  not_from:
    - "unavailable"
    - "unknown"
The button still works, but I’ll wait and see if it solves the ghost presses.
I can't find a way to edit my post, but just to update, the change in code works well. No more "ghost" presses, and the buttons are working perfectly well in all ways.
