@filippos, I managed with the Discord group staff to solve our problem follow the code ready you now just rename your variables
Awesome.
Your code works great when sensors send two codes, one for ON and one for OFF.
If sensor sends only one code then the delayed_on_off doesn’t have a real meaning and status remains in a constant ON mode.
Therefore, for one code sensors i changed the code slightly into this:
rf_bridge:
on_code_received:
then:
- homeassistant.event:
event: esphome.rf_code_received
sync: !lambda 'char buffer [10];return itoa(data.sync,buffer,16);'
low: !lambda 'char buffer [10];return itoa(data.low,buffer,16);'
high: !lambda 'char buffer [10];return itoa(data.high,buffer,16);'
code: !lambda 'char buffer [10];return itoa(data.code,buffer,16);'
- if:
condition:
lambda: |-
return data.code == 0xCCFFAA;
then:
- binary_sensor.template.publish:
state: ON
- delay: 5s
state: OFF
binary_sensor:
platform: template
device_class: door
and it works like a charm. It goes OFF after 5seconds.
Hi, i’m looking for a way to trigger an automation in HA when a specific code is read on Sonoff rf bridge with esphome. Tried this but don’t work… Why?
automation:
platform: event
event_type: esphome.rf_code_received
event_data:
data: 8S24C3 # code read by RF bridge
try this one, just substitute data to code
- platform: event
event_data:
code: 8S24C3
Works like a charm for me to! Now I am struggling what to do if you have multiple binary sensors? Any suggestions? Can’t seem to get the if statement right: I have 6 doorsensors which all return a code to the sonoff device.
I have Sonoff RF-bridge running with ESP Home and Portisch firmware.
I want to monitor/persist the Open/Close state of my door/window sensors and the state of my alarm in HA to add some automation rules and intelligence to my alarm.
The sensors and rf codes are set properly and I do receive event changes in HA some of the time. But these sensors (Binary switches) goes unavailable most of the time. And I loose state changes and I am left with wrong states in HA.
Here are some examples from my esp home code:
- platform: remote_receiver
device_class: motion
rc_switch_raw:
code: '000111101010010101011100' #1EA55C
protocol: 2
filters:
delayed_off: 400s
rc_switch_raw:
code: '111000001001001100001010' #E0930A
protocol: 2
filters:
- delayed_off: 5s
rc_switch_raw:
code: '111000001001001100001110' #E0930E
protocol: 2
filters:
- delayed_off: 5s
I have about 40 of these code blocks (sensors).
I guess I read somewhere the issue is caused by the large amount of code in the RF bridge Esp code. I reduced this to the minimum but no significant difference.
Any idea what I can do?
I wanted to share my implementation of this hardware/firmware combo as it appears to be a novel one. Not that I take any credit as it’s a combination of two other ideas. First, I program the rf bridge to trigger HA events whenever it receives a RF code. This is the example code given on the esphome website.
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: XXXX
password: XXXX
captive_portal:
web_server:
port: 80
ota:
api:
services:
- service: send_rf_code
variables:
sync: int
low: int
high: int
code: int
then:
- rf_bridge.send_code:
sync: !lambda 'return sync;'
low: !lambda 'return low;'
high: !lambda 'return high;'
code: !lambda 'return code;'
- service: learn
then:
- rf_bridge.learn
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 19200
logger:
baud_rate: 0
rf_bridge:
on_code_received:
then:
- platform: wifi_signal
update_interval: 60s
switch:
- platform: restart
text_sensor:
- platform: wifi_info
ip_address:
Then I use node-red to read these events when they trigger and determine if the code matches any of my sensors. If so, publish to a mqtt topic that HA can read. I do this with three nodes:
- Home-assistant:events:all - configured to watch for esphome.rf_code_received events
- Function:python function - configured as per the following code
- Network:mqtt out - no special configuration; just connected to my broker
The python code does most of the work and is easily updated:
codes = {
'000X0X':['backdoor','ON'],
'000X0X':['backdoor','OFF'],
'0X000X':['garagedoor','ON'],
'0X000X':['garagedoor','OFF'],
'00000X':['garagemotion01','ON'],
data = msg['payload']['event']['code']
if data in codes.keys():
msg = {}
msg['topic'] = 'home/{}/status'.format(codes[data][0])
msg['payload'] = codes[data][1]
return msg
Then I configure sensors in home-assistant to listen to the appropriate mqtt topics (ex. home/garagedoor/status)
- platform: mqtt
state_topic: "home/backdoor/status"
payload_on: 'ON'
payload_off: 'OFF'
device_class: door
- platform: mqtt
state_topic: "home/garagedoor/status"
payload_on: 'ON'
payload_off: 'OFF'
device_class: door
- platform: mqtt
state_topic: "home/garagemotion01/status"
name: "Motion Sensor Garage Indoor"
payload_on: 'ON'
payload_off: 'OFF'
off_delay: 2
Hey. I did everything according to your instructions. I can accept codes from the remote control. but it doesn’t work. can you help?
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: "pass"
password: "pass"
use_address: 192.168.0.237
manual_ip:
static_ip: 192.168.0.237
gateway: 192.168.0.1
subnet: 255.255.255.0
# Enable logging
logger:
web_server:
port: 80
# Enable Home Assistant API
api:
password: "apipassword"
ota:
password: "otapassword"
remote_receiver:
pin:
number: 4
dump:
- rc_switch
filter: 50us
idle: 2ms
remote_transmitter:
pin: GPIO5
carrier_duty_percent: 50%
switch:
name: RF Power Button
turn_on_action:
- remote_transmitter.transmit_rc_switch_raw:
code: '111111110101111101110001'
protocol: 1
Same here. Receiver works but not the transmitter.
I have rf bridge hacked.
Finally I managed to transmit protocol 1 rf code.
My settings:
switch:
optimistic: true
assumed_state: true
turn_on_action:
code: '100010001010101000000001'
protocol:
pulse_length: 320
repeat:
times: 10
wait_time: 0s
Please try it and check if it works.
Interesting. I think @andreaslindner 's config work around (Here)
which has been solid for me broke with updating Esphome to 1.16.0, potentially relating to this issue:
Replacing with your settings have fixed it for me.
Thanks!
Been trying to get my sonoff rf bridge to receive and send codes from Zemismart blind remote AC123-06.
Began with Tasmota and portisch but with no success. I could se the binary but did not succeed in keeping the setup, and after reboot of the RF bridge, the “raw.mode” reverted to “standard”
Progressed to ESPhome with this setup:
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: !secret wifi_ssid
# Enable logging
logger:
baud_rate: 0
uart:
tx_pin: GPIO01
rx_pin: GPIO03
baud_rate: 19200
api:
password: !secret api_password
services:
variables:
sync: int
low: int
high: int
code: int
then:
- service: learn
then:
- rf_bridge.learn
rf_bridge:
on_code_received:
then:
ota:
password: !secret ota_password
web_server:
port: 80
name: Sonoff RF Bridge Wifi Signal
update_interval: 10s
- platform: uptime
name: Sonoff RF Bridge Uptime
binary_sensor:
- platform: status
name: Sonoff RF Bridge Status
remote_receiver:
pin: 4
dump: rc_switch
tolerance: 50
filter: 4us
idle: 4ms
remote_transmitter:
pin: 5
carrier_duty_percent: 100%
status_led:
pin:
number: GPIO13
inverted: yes
Have done all the hardware mods, it still receives al the old known signals but now in biniry and not the hex codes so far so good.
But my Zemismart remote omly reads as “00000000”
No matter which button I press I get the same result in the logs:
[remote.rc_switch:256]: Received RCSwitch Raw: protocol=1 data=‘00000000’
Any solution to get the RF bridge to read the Zemismart?
I can’t recall where/when I saw it, but I recall the Sonoff can’t do all rf codecs even with the hardware hack. I ended getting and using a broadlink to learn/send codes for my blinds. I had similar symptoms of “incomplete looking” codes being logged/received. Sonoff RF Bridge with ESPHOME?
Perfect! Thanx a lot
my old settings :
name: Remote Front Gate Control
turn_on_action:
code: 'xxxxxxxxxxxxxxxxxxxxxxxxxxxx'
protocol: 1
repeat:
times: 10
wait_time: 10ms
Hi guys,
Sorry if it’s a nood question, I’m pretty new to rf433.
i’ve got a sonoff rf bridge modified (cut on the lines, etc …)
I’ve flashed esphome and dumping rf_switch.
Then I’m testing my brand new RM433 remote.
My issue is that the top left button and second line right button give me exactly the same code :
#Press on top-left button
[21:22:51][D][remote.rc_switch:256]: Received RCSwitch Raw: protocol=1 data='011110000100000001001000'
#press on second-right button.
[21:22:53][D][remote.rc_switch:256]: Received RCSwitch Raw: protocol=1 data='011110000100000001001000'
then I don’t know how to distinguish them on config.
All other buttons have differents codes.
Do you know id I did something wrong ?
Have you tried dumping “all” or “raw” just to make sure ?
As a side node: I don’t understand why by default people assume you have to do the hardware “hack” on the RF Bridge for ESPHome… I use it with Portisch firmware, but I don’t know if I even had to flash that, 'cause all my devices seem to work out of the box.
My recommendation with the RF Bridge would be:
- Try it with ESPHome without any modifications
- If you have devices that don’t work: try using Portisch firmware for the second chip
- If all else fails, do the hardware “hack”, but know you essentially now have an ESP8285 with a generic receiver/transmitter duo.
The hardware hack is a bit of an abomination
I’m just getting into this pretty late I guess.
I purchased 11 RF 433 MHz door sensors, and 3 water leak sensors. I put Tasmota on my RF Bridge. Water leak sensors work great, but the door sensors often don’t see when the door goes from open to close (probably once ever 5 times on some doors). I would love for the to work 100% of the time. I often get alerts a door is left open when it is in fact close.
it seems if I put ESPHome on my bridge it would work better, but I kept reading how you have to solder two connections and cut three lines. Not the end of the world, but I would love to test ESPhome first. If I can test it out without doing a hardware hack that would be great.
Could you point me to where I put ESPhome on the RF Bridge without a hack? Thanks.
I don’t think ESPHome will make your RF Bridge work better than with Tasmota.
The reason your door sensors don’t work all the time is probably because if you have 11 a lot of them are probably on the edge of the reach of the RF Bridge. My advice would be to either get 1 or 2 extra RF Bridges or maybe build a custom RF solution with better chips and/or antenna’s…
If you still want to try ESPHome just to try it:
Just make the .bin file and upload it through Tasmota, it supports writing ESPHome firmware directly.
