after I was trying 6 hrs yesterday to connect my Sonoff RF Tasmota, I quit and going to ask the nice community for some help. I tried all types of confifurations without success, but I am also really new to all of this.
Here is my setup:
Synology DS916 running HA v69.1 in Docker
Sonoff RF running Tasmota v5.91
It looks like HA is having difficulty contacting your mqtt server. Your sonoff is probably connecting fine to the mqtt server.
I found when up setting mqtt devices, its handy to use a mqtt client on my machine. Google chrome has one built in as an extension or there are a lot of stand alone programs. I then subscribe to my sonoff topic with the wildcard # to get all the mqtt traffic or just subscribe to all topics on the mqtt server if its not too busy.
Yes the IP is correct and I also can Ping it. I dont have other MQTT Clients or server to try. Right niw I am tryinf to setup a Mqtt in docker to see how this works.
Just ried with Mqttlens. Also no connection at all.
When you run Hass.io, you can install a MQTT Server as an add-on. Without Hass.io, you have to manually install the MQTT Server. It’s an extra piece of software that needs to be installed first. The configuration in configuration.yaml only tells HA where to find the server - but it does not install or run the MQTT server.
This is correct. To set up the embedded broker, you just need the following line in your configuration.yaml
mqtt:
It is limited in functionality, but will do the job to get you going. You do not need hass.io. See this page
Edit:
The default configuration for the embedded broker is here.. As you can see, if you just have mqtt: in the configuration file, the user is homeassistant, so you need to set that as the user in your sonoff. Everything else looks ok, but try that first.
Thx gpbenton. That was the glue. I totally missed to see this. So my fault was I did not put the User (homeassistan) and my API Pasword. After inserting this to my Sonoff, connected directly. Thanks everybody for the help…
