Does anyone know if the SONOFF S31 Lite smart plug will report its State for IF then Automations in HA? IE if I were to turn it On with Alexa (linked via smart things) would HA know it was On? or would it still show it off?
Some devices like those turned on via an IR blaster will incorrectly report they are on even if the blast missed, just want to know if this plug will report accurately?
If not, any suggestions for a Smart Plug that will\work with HA\Smartthings?
How would it know? What have you set to talk to the S31? (How did you integrate it? )There are two choices. The eWeLink - Add-on or the HACS - AlexxIT Sonoff LAN
Otherwise there would have to be communication set up between HA and a Smart Things Controller of some sort (another Integration)
It would be direct connected via a Home assistant integration or via Smartthings… So the Entity would be in HA, I just need to know if it would be “aware” of its state vs just an on off toggle in HA
The Zigbee version was the plan. So is this a confirmation smartthings will know the plugs state vs just things its on\off base on the last button press?
