I am using a Sonoff SV and ESP home to control my garage door. It has worked flawlessly for 3 years with the exception of about once per week or so, the relay does not turn off. To trigger my garage door, I turn on the relay and then pause for 1/2 second and then turn it off. Sometimes the relay just stays open which requires me to have to hit the button again to turn it off. Not a but deal, but it messes with my automation, and also does not allow me to use the real button on the wall in the garage as their is not power, the LED is not lit. Should I adjust the 1/2 second pause? Has anyone else had these issues?
Here is my code for the switch.
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid:
password: "
manual_ip:
static_ip: 192.168.1.146
gateway: 192.168.1.1
subnet: 255.255.255.0
# Enable logging
logger:
# Enable Home Assistant API bw
api:
ota:
binary_sensor:
- platform: gpio
pin:
number: GPIO14
mode: INPUT_PULLUP
#inverted: True
name: "Welle Garage Door"
device_class: garage_door
- platform: gpio
pin:
number: GPIO12
allow_other_uses: true
name: "Garage Relay Button"
filters:
- delayed_off: 20seconds
- platform: wifi_signal
name: "Garage WiFi Signal"
update_interval: 60s
switch:
- platform: gpio
pin:
number: GPIO12
icon: "mdi:arrow-up-down-bold-outline"
name: "Welle Garage Switch"
turn_on_action:
- switch.turn_on: relay
- delay: 500ms
- switch.turn_off: relay
