jerry_nz
(Jeremy Pickett)
1
Hello there!
Would anyone know if you can wire a Sonoff switch between a LED-powersupply, and a computer fan?
Or does it have to have mains-power for the input?
Thanks in advance!
power supply “looks” like this one (currently at work so don’t have specifics):
Cain
2
You wouldn’t be able to wire it in between as the sonoff takes AC and this outputs 12V DC.
jerry_nz
(Jeremy Pickett)
3
facepalm - of course
thank you
I’ll need to think of another way to power up/down the fan
bukurat
(John)
4
Have you thought about the Sonoff SV?
It will run off 12V DC and you can easily change it to dry contact switching.
jerry_nz
(Jeremy Pickett)
5
haha - i was JUST looking at them here:
https://www.aliexpress.com/item/Sonoff-SV-Safe-Voltage-WiFi-Wireless-ON-OFF-Switch-Smart-Home-DIY-Module-5-24V-Control/32837937072.html?
I would need it to be accessible via home-assistant though which looks like it might be the road-block (unless i’m searching the wrong terms!)
bukurat
(John)
6
Flash it with tasmota firmware and control it via MQTT
You can run a basic from 5v DC, so just knock up a regulator to get down from 12v. Then make it dry switching and connect the 12v to the relay.
I did this with one but started with 12v AC so added a bridge rectifier before the voltage regulator.
jerry_nz
(Jeremy Pickett)
8
I think that’s the ticket! thank you @bukurat
I didn’t realise the tasmota firmware works for more than just the ‘basic’ sonoff - wicked cool!
thanks!
bukurat
(John)
9
It will with almost anything that has an esp8266 or equivalent in it.
