Sonoff Switches Indicating wrong Status
My Sonoff (tasmota) switches show the wrong status after rebooting, some show ON and some OFF, even though they are all ON. The config is all the same for all the switches, as follows, what could be the problem:
  - platform: mqtt
    state_topic: "stat/mainbedsidelamp/POWER"
    command_topic: "cmnd/mainbedsidelamp/POWER"
    availability_topic: "tele/mainbedsidelamp/LWT"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    payload_available: "Online"
    payload_not_available: "Offline"
    retain: true
#  - platform: command_line
#    switches:
#     tsakibackup:
#      command_on: "/usr/bin/curl -X POST http://192.168.1.133/cm?cmnd=Power%20Toggle"
#      command_off: "/usr/bin/curl -X POST http://192.168.1.133/cm?cmnd=Power%20Toggle"
#      command_state: "/usr/bin/curl -X GET http://192.168.1.133/cm?cmnd=Power"
#      value_template: '{{value_json.POWER == "ON" }}'
#      friendly_name: Bedside_Lamp_Backup
  - platform: mqtt
    state_topic: "stat/efergymeter/POWER"
    command_topic: "cmnd/efergymeter/POWER"
    availability_topic: "tele/efergymeter/LWT"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
  - platform: mqtt
    state_topic: "stat/Lights_Ups/POWER"
    command_topic: "cmnd/Lights_Ups/POWER"
    availability_topic: "tele/Lights_Ups/LWT"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
  - platform: mqtt
    state_topic: "stat/Lights_Downs/POWER"
    command_topic: "cmnd/Lights_Downs/POWER"
    availability_topic: "tele/Lights_Downs/LWT"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
  - platform: mqtt
    state_topic: "stat/Bedside_Plugs/POWER"
    command_topic: "cmnd/Bedside_Plugs/POWER"
    availability_topic: "tele/Bedside_Plugs/LWT"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
  - platform: mqtt
Default update time is 300 seconds, maybe it’s not updated after reboot
try changing “teleperiod” in Tasmota console to less than 300
Thanks, my teleperiods were the problem, now sorted
