I have a Sonoff SWV-ZF2 Hydro Duo in my Zigbee (tasmotised SONOFF bridge) there is no flow meter, it only has the two switches for on off, does anyone have flow meters ?
Hi Dave, which integration are you using?
Here you can see what this device exposes in Z2M: SONOFF SWV-ZF2 control via MQTT | Zigbee2MQTT
Hi Nick I went with the built in zigbee zha as I figured it would be the best way given it’s built in?
I found a zha tweak to support the device so all is well.
zha:
enable_quirks: true
custom_quirks_path: /config/zha_quirks
