Hello everyone,
Does anyone know if a changelog for this is available anywhere?
Yesterday, I updated my TRVZB devices to firmware version 1.3.0 using Zigbee2MQTT, and everything seems to be working fine.
However, for future updates, it would be helpful to review the changelog before proceeding with the update.
Thanks in advance for any information!
Did you manage to find this information? thanks
Unfortunately, nothing so far.
Co-incidentally, when I logged into Home Assistant this morning, it was reporting that new firmware 1.3 was available. I have upgraded via ZHA but don’t know what’s changed.
Well, I don’t know about ZHA. I’m using zigbee2mqtt which is well documented and changelog is acurate.
Thanks, I was referring to Sonoff TRVZB firmware being updated to 1.3. I upgraded via ZHA.
V1.3.0
New Updates:
- Support Adjust Accuracy in eWeLink APP. When the Temp. Accuracy is set to the default of 1°C with a target temperature of 26°C, the SONOFF TRVZB valve closes at 26°C and opens at 25°C. Alternatively, when set to 0.4°C, it closes at 26°C and opens at 25.6°C.
2.A lower accuracy level minimizes temperature fluctuations but comes with increased battery usage. - Support automatic switching between daylight saving time and standard time.
- Refined certain English copy:
In the device user interface:
- off→Standby
- OFF(Frost-protection)→Anti-freeze Mode
In the device settings:
- Frost protection→Anti-freeze Mode
*Currently, only ZBBridge-P gateway is supported, which must be upgraded to V2.4.0. Other Zigbee gateways will be supported in future updates.
*These features require updating the eWeLink app to V5.14.0, expected to be released in early March.
