A few questions about this device:
- Does the faucet also close partially, or does it always open and close completely to regulate the temperature?
- Can it also be used offline? That is, if I set a temperature on the valve, say 20 degrees, does it work even without a ZigBee hub?
- Can I calibrate the temperature, for example, if the valve indicates 2 degrees higher than the room temperature?
thanks
