Sonoff VIP
I am looking for a product similar to Sonoff basic but that has the function of power on maintained after a power outage and that has more stability in the connection with your app, is there a switch with these functions? can the sonoff be modified to work in a stable and secure way with your app? What is the product called? or what firmware should I use to achieve these objectives? I will appreciate all your help as it is very important for the project I want to do.
How is this a feature request? Hopefully someone can move it.
More stability than what?
What d you mean more secure? What are you securing it from?
more stability in the connection to the internet, it connects for 4 hours, it disconnects other 2 and so, it never keeps a stable wifi connection.
when you are with the sonoff activated on and the current is cut, when the power returns the sonoff does not turn on automatically.
security I meant stability in the wifi
you can help ? Can this device be modified to work well or do you know another product that is the same or better than this one that has what I need? Thank you
celularespia*gmail
All of those are down to you not setting it up correctly in the first place and your network being poor.
Do it right and they are 100% stable.
I would agree, mine are very stable. Tasmota firmware is great. Stock, they have to talk to a server halfway across the world each time.
Adding a bunch of WiFi iot devices can stress your network. I ended up upgrading my network and it made a big difference.
I do not use tasmota firmware, use original sonoff, can you modify the firmware sonoff 1.6? Is there another product with similar characteristics? as it is called ? I have 10 sonoff on the same internet network half the other does not.
Flash with tasmota.
Use decent wifi hardware, eg ubiquiti.
EDIT: See here for power on options:
Hello, someone sells the Sonoff with the Tasmota Firmware ready to use? Tasmota has App to manage in Playstore and Appstore?
Ubiquiti Which hardware?
I need an administrator on / off by means of an android APP / ios, what is the device that I need to buy I need a light in my way I am lost and I need to automate my devices .
This is a home assistant forum.
You can use home assistant via an iOS app and using a web browser in android.
I am not aware of anyone selling sonoff devices with tasmota pre-flashed, it is not difficult to do yourself.
Tasmota does not have an app, and even if it did that has nothing to do with home assistant.
Home assistant will automate your devices without some app.
this smart swicht knowing ? https://www.mokosmart.com/product/moko-hot-sale-indoor-mini-wifi-smart-socket-power-plug-wifi-smart-oulets-solutions/
What?
Aside from your seeming misunderstanding of what this forum is about, on searching the forum I cannot see any reference to this switch on this forum.
From what I can see on the website (and the photos are not that great) it does not appear to pass through the earth connection, and if so it is HIGHLY dangerous.
Other than that quite obvious flaw, there is no indication of how it actually works, whether there is an API, whether it is flashable with useful firmware, or any other details that might help answer whether it is compatible with home assistant. In it’s native implementation it uses a cloud solution, which is enough for most people on this forum to not want it unless it is flashable.
And besides, you already seem to have a solution that will work. Sonoff flashed with tasmota.
I hope by now you have got that this is not a general hardware review site. We don’t care if the device meets YOUR needs, we are interested in home assistant integration.
Cheers.
