I know that the answer to queries about Zigbee range is usually “add more repeaters”, but my range seems really bad.
I’ve just set up a Sonoff ZBDongle-P on Zigbee2MQTT. I’ve paired a bunch of devices with it and have pretty low LQIs all round so I’ve been doing some experimenting.
I have a TuYa TS0201 battery powered temperature sensor positioned 190cm away from the dongle. It has a line of sight and is reporting an LQI of around 50. I’ve got no prior experience of Zigbee, but reading around, that sounds like a terrible LQI.
I also have a pair of Tuya TS0001 mains powered switch modules about 5 metres away (but on the other side of a couple of brick & breeze block walls) which get LQIs of under 30 and intermittently lose their connection.
Here’s what I’ve tried:
- Turned off my Wifi for all of these tests
- Upgraded the dongle firmware to the latest
- Turned up the dongle power to 20dBm
- Tried channels 11, 15, 20 and 25.
Nothing seems to make much difference to the reported LQIs. The dongle is plugged into a USB 2 port via a 1 metre USB cable.
