Hello my friends:
I am Ruben from Spain.
Using Some ZBMINIR2 with zb2mqtt
I am using with detach relay mode ON becouse i want use pulsation for some more actions like double click.
I can see pulsation on relay like a “toggle” action on the ZBMINIR2 device.
How can i have double click with this device?
Thank’s a lot.
My question is:
AFAIK, you can’t, the only event the device generates for the switch in detached mode is “toggle” (which is the main reason I was very disappointed when I got this device, because its detached mode is basically useless if you need to track the switch state manually).
I understand ! What device are you using now?
A Shelly. Not Zigbee (alas) but its detached mode is what you expect.
Tnx a lot. I am using also Shelly on my home on other places.
English please.
I flagged it as (LLM-generated) spam.
