Sonoff Zigbee Bridge
I have a running Sonoff Zigbee Bridge flashed with Zigbee2Tasmota (ncp-uart-sw_6.7.6_115200) not (ncp-uart-sw_6.5.5_115200) for HomeAssistant. I can’t change the firmware because it’s integrated to Control4 via Tasmota/MQTT. Is there a way to identify the Zigbee devices from HA?
Can you tap into the MQTT feed that the Zigbee Bridge is publishing to? It sounds like it is publishing to a MQTT servers somewhere on your network. If you can view the messages on this MQTT server using a tool like MQTT Explorer, then you can see what data is available from that direction.
