Sonoff Zigbee Dongle has stopped working
Zigbee has been working fine for months and suddenly I have started gettting the following error:
Error setting up entry Sonoff Zigbee 3.0 USB Dongle 3.0 - /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_2a766a3563c9eb1188628d4f1d69213e-if00-port0
I became aware of the problem when I tried to add a zigbee device, a smart switch. The device could not be seen. After a restart, I realised ZHA hadn’t loaded correctly.
I am running HA on a NAS under HAOS.
I have tried:
  • Deleting and reinstalling ZHA
  • Deleting zigbee.db before reinstalling
  • Removing the aerial and restarting
I have read everything I can find on the forum but cannot find a solution.
In desperation I have updated to the very latest version of HA. I was hoping that a bug had been corrected. Now HA is behaving differently and the Zigbee Dongle is not being auto-discovered any more.
My HA versions are:
Home Assistant Core 2022.6.7
Home Assistant Supervisor 2022.05.3
Home Assistant OS 8.2
Help!
Possibly faulty?
Since you are using /serial/by-id/ it’s unlikely the port has changed, but I would login via SSH and run
ha hardware info | more
and see if the OS can at least see it.
What firmware version are the Sonoff dongle. 20220219 is latest. Maybe a problem if it is very old?
Well done khvej8, you have solved the problem. I didn’t know what firmware version I had but I now have the latest. Everything has come back to life.
