Hi, I’m new using Home Assistant.
I try to make Automation for turn on and turn off Sonoff POWR316 using time triggered. I use Sonoff POWR316 to monitor and control AC.
The scenario are: Sonoff will turn on at 8.00 AM and off on 8.00 PM, so the AC can only on bettwen 8.00 AM - 8.00 PM
Time triggered work well. But the problem came the next day. Sonoff didn’t turn on but when I check log history at HA, the time trigged was active. Is there any configuration did I miss?
Did you look at the traces of the automation?
How does it look like?
This is when they triggered:
What if you click on the orange node? what do you see?
Do you realise that this is a turn_off and it is from 8pm?
I mean, here, in Belgium, it is 10am already, but it seems to me that there is nothing triggering the turn_on or is it another automation?
Yes, I made separated automation to turn on and turn off. Previous screenshot is traces from yesterday. Here is traces from today:
- alias: Turn On/Off Lt.1
- platform: time_pattern
hours: '20'
minutes: '0'
seconds: '0'
alias: In the evening
hours: '8'
minutes: '0'
seconds: '0'
alias: In the morning
condition: []
- if:
- condition: trigger
then:
- service: switch.turn_off
data: {}
entity_id: switch.sonoff_10017e8d4e_1
- if:
then:
- service: switch.turn_on
data: {}
mode: single
EDIT replaced [] with {} for data, my eyes are bad
Have a look at my automation above to merge the 2 (made in the editor, might need some debug).
In your screenshot, it seems that it is not the latest execution, is it?
Yes, my bad, edited, it is {}, not []
Ok, thank you. I’ve tried your code in short time duration and it work.
I will tried in long time duration I will give you an update tomorrow.
Update:
It works well, thank you Oliver
