That’s normal. My logs are full of that as well. In my experience sonos works somewhat okay but there are lots of errors in the logs. Not just those. I don’t think there is much interest from developers to fix it, most of the Sonos issues get closed for inactivity and never get resolved.
I haven’t tried getting it to work perfectly but considering there are better supported Sonos APIs I have considered switching to a nodejs http API I tried in the past and had positive results from.
for some reason it was making HA run so slowly… So I turned off the offending Sonos and speed picked up again. I might even try to factory reset it and see what happens. I only want to use it for TTS as part of an alarm
I had 1 of my Sonos off for a week and didn’t once get this error in the logs. Yesterday I factory reset to Play 1 that caused the problem. It was fine till yesterday but today the logs are again full of this
2017-09-23 22:59:11 WARNING (MainThread) [homeassistant.components.media_player] Updating sonos media_player took longer than the scheduled update interval 0:00:10
2017-09-23 22:59:22 WARNING (MainThread) [homeassistant.components.media_player] Updating sonos media_player took longer than the scheduled update interval 0:00:10
2017-09-23 22:59:33 ERROR (MainThread) [homeassistant.helpers.entity] Update for media_player.dining_room fails
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 141, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py", line 83, in create_connection
raise err
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/requests/packages/urllib3/util/connection.py", line 73, in create_connection
sock.connect(sa)
TimeoutError: [Errno 110] Connection timed out
Then constaly these afterwards
2017-09-24 08:14:05 WARNING (MainThread) [homeassistant.components.media_player] Updating sonos media_player took longer than the scheduled update interval 0:00:10
2017-09-24 08:14:16 WARNING (MainThread) [homeassistant.components.media_player] Updating sonos media_player took longer than the scheduled update interval 0:00:10
2017-09-24 08:14:27 WARNING (MainThread) [homeassistant.components.media_player] Updating sonos media_player took longer than the scheduled update interval 0:00:10
2017-09-24 08:14:38 WARNING (MainThread) [homeassistant.components.media_player] Updating sonos media_player took longer than the scheduled update interval 0:00:10
2017-09-24 08:14:49 WARNING (MainThread) [homeassistant.components.media_player] Updating sonos media_player took longer than the scheduled update interval 0:00:10
2017-09-24 08:15:00 WARNING (MainThread) [homeassistant.components.media_player] Updating sonos media_player took longer than the scheduled update interval 0:00:10
2017-09-24 08:15:11 WARNING (MainThread) [homeassistant.components.media_player] Updating sonos media_player took longer than the scheduled update interval 0:00:10
2017-09-24 08:15:22 WARNING (MainThread) [homeassistant.components.media_player] Updating sonos media_player took longer than the scheduled update interval 0:00:10
2017-09-24 08:15:33 WARNING (MainThread) [homeassistant.components.media_player] Updating sonos media_player took longer than the scheduled update interval 0:00:100:
The Sonos integration was mostly rewritten about a year ago and now works quite well. If you still see problems, file a GitHub issue so we can investigate.
