Can you share your config? Looks like you are using it as a sensor as the error says sensor.braviatv_psk not found. The component should be a mediaplayer.
Thanks for taking a look. My code is the same as this, other than the Mac and IP. Not getting the error anymore, but all it can do is turn the TV on and that is only if it is already off. Once it is on, it seems to lose control again if the cable box is on. Is it only for use with HA and not a cable box for example?
Correct - the path is config/custom_components/media_player
psk is “sony” , no 0’s
what do you mean by remove the braviatv platform? as I mentioned, it was discovered as part of the LAN I assume, as it was in HA before I started digging into it.
I have tried android: True in the config, didn’t make any difference
I deleted the BraviaTV stuff from the config.yaml file - rebooted the server and the Bravia TV app still shows on the dashboard, like it did upon the initial boot up. Where else would it get the config info from?
Hello, I’m using the normal sony bravia tv compontent and I can power on or off the tv. But I can’t do anything else. Is there a possibility to start the netflix app? Thank you in advance !
@gerard33 thank you very much for making this component. I’ve just installed on 0.63.3 and it works well on the first time.
By the way, after several minutes (with some testing like turn on, turn off, change channet etc.), this component doesn’t work any more. I got the following HA’s log:
No data received from TV. Error message is: time data '' does not match format '%Y-%m-%dT%H:%M:%S'
11:55 PM custom_components/media_player/braviatv_psk.py (ERROR)
Can you also try the version in the link above?
I have changed some logic in the code that get’s the end time of the TV program that is playing as that is probably causing the issue you have seen in the logs.
I’ve just test this version and I’ve not found the previous bug any more. Thank you.
Error while setting up platform braviatv_psk
File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 84, in async_setup
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 245, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/config/custom_components/media_player/braviatv_psk.py", line 70, in setup_platform
[BraviaTVDevice(host, psk, mac, name, amp, android, source_filter)])
File "/config/custom_components/media_player/braviatv_psk.py", line 79, in __init__
from braviapsk import sony_bravia_psk
ModuleNotFoundError: No module named 'braviapsk'
Looks like it can’t download the module from PyPi which is needed for the actual connection with the TV.
I am running the component on hass.io as well so that’s not the issue.
Does your HA have connection to internet? And can you restart HA once more to see if that solves it?
This is awesome! Thanks for your hard work on this! Is it possible to get it to pull stations from a HDHomerun? I share a HDHR tuner between several Bravia TVs in my house since support was added in the 7.0 update.
