I’ve tried searching, but cannot find anything other than a simple switch implementation for on/off of a Sony projector.
I know more is possible as I have it controlled via Control4 currently including changing sources and switching resolutions which I want to have available in HA.
Any pointers as to an integration / media player for this?
I’ve tried pjlink as well but not getting anything more on this.
Model number is Sony VPL-VW760ES. I found a GitHub repo that does a little more, but not much using pysdcp on GitHub here. It’s not built for HA though so would take some work. I was hoping that there would be something available already.
Sorry if I wasnt clear but i am asking what functions PJLINK controlled?
Looking at code for pjlink it looks like it should provide source state, source available, source change, on/off and volume. I never use pjlink with HA but i have projectors with this function and i believe it control these basic functions. They were panansonic however.
You can also use serial control over ethernet and use something like the command line integrations to add it into HA
I’ve never managed to get the PJLink function to work. Nothing showing anywhere in logs that I can see and no presence of the projector anywhere in HA. The only option I had working was a simple on/off switch, I can’t remember what integration I used for this now but I removed it when I tried to get the PJLink integration working.
which is in the media_player: section of my configuration.yaml. The port I have taken as indicated in the Sony PJ web interface for PJ Link protocol settings. I also tried adding an authentication parameter with the login details used for the web interface (probably not the right creds). I’ve restarted HA in between each change and nothing ever shows up.
Hi there, I’m trying to get Sony VPL-XW5000 integrated with HA. I’m using a legacy entry in the configuration.yaml file but not sure how I can find it within HA.
I’m thinking of getting a VPL-XW5000, but it sounds like the integration is suprisingly basic, and I’d like to have control over more than just on/off.
Sony has a good api and there are several connectivity standards it supports. HA in general supports it just fine. Honestly the integration is annoying as, just like most media player integrations, the device must be ON and communicating when HA is rebooted or it h h led “unavailable”. I leave my PJ running 24/7 so it’s a rare pain but an immediate pain during power outages. This will be same for any projector
you can use template, telnet or another method for any missing features or some other protocol. I think these methods survive power outages better but never paid attention to confirm.
Didn’t get very far with my 760ES. I did manage to get it to power on and off over telnet but I have no state information yet so it’s gone in the pile for another day.
Meant to add, I don’t have a serial cable over there, so unless I get an IP / Serial interface, that’s out of the question. But your point is valid, my Control4 system is controlling it, so it must be possible!
760 seems to be consumer version of xw5000. At least that’s how this is normally done, Consumer and pro being same unit with difference being warranty and model #.(and price)
If you have serial port I’m am 100% certain that .pdf applies. My Sony also has “Crestron control” which was basically documented standard for plug and play to Crestron. But if it has that it —again— definitely has a standard serial control api.
Never got this working well using this approach. I was just about to undertake creating my own integration to try and replicate how my Control4 integration works, but turns out someone else has recently created one. Link below for anyone that didn’t come across it already.
