Soundavo Ws66i - Home Assistant Configuration
I’m about to purchase the Soundavo WS66i. Before I pull the trigger, I’m confused if HA (Home Assistant) can control the WS66i amplifier simply through the Ethernet port or does it have to be connected via the RS-232 cable?
My new setup:
  • Fully smart home (new house/under construction)
  • Hoping to run HA via Raspberry Pi (any other suggestions?)
  • All Kasa Smart Light switches
  • Looking to add motion sensors (undecided)
  • ReoLink security cameras
  • Confused about the audio system, since unsure of the above
Audio setup:
  • 4 x bedroom, each with TV’s and 2 pairs of in-ceiling speakers (each)
  • Soundavo WS66i??
i’m in the same boat - and looking between this and the dax88. I know dax88 has integration.
Lets work together on this!
This definately has the integration - just unsure how to make it communicate it with HA - getting mixed information. Some say with RS232
there’s another thread discussing it Monoprice Whole Home Audio controller 10761 success - #113 by Zinic
The RS232 is for the Monoprice amp; it does not have an ethernet port. The WS66i amp on the other hand can be controlled by Home Assistant just be connecting the amp to the network via an ethernet cable.
I am looking at that for some time already.
DAX88 does have ethernet port too but I recently discovered, that even though the integration is still by RS.
WS66i integration is by TCP/ethernet which is much better imo.
DAX88 is much better with specs though as it has better amplification (25W on ws66i vs 75W on dax88).
So I would like to know if it is possible to integrate DAX88 to HA through TCP/IP and not some old school tech from the 90s :wink: (which I remember well).
I have more than 8 zones to power so I will be adding slave unit.
This is becoming even tougher as soundavo’s second unit EXT66 is cheaper than DAYTON’s second DAX…
To make it even mroe complicated - Spotify connect is important to me.
And I want it as native as possible.
Ideal scenario would be to have separate devices available in spotify app (for zones) (only configured once in the amp app) and have it as transparent as possible - the best would be - without even noticing there is an audio system involved.
another question to DAX vs WS66i is:
DAX88 has only one wireles input while WS66i has two, which means that with DAX only one user can stream spotify to his zones and the other user cannot use spotify.
with ws 66i we have 2 users playing simulatneously.
Anyone?
Yes you can using the ethernet port/LAN/WLAN.
Install the Soundavo integration, configure it (name the sources).
Add to Dashboard button.
Just wanted to say a quick note of thanks to all here for the help and inspiration.I’ve decided to sell the soundavo as I got an amp with multiple zones that now fulfils the role I had for the soundavo. If anyone in Europe wants a Soundavo WS66i without all the hassle of import, taxes etc, ping me a message. I’m based in Belgium, and have not used the device more than 20 times.
What amp did you get? Is it controlled with HA? I’m about to pull the trigger on a WS66i (in the US) but I’m open to looking at other options.
Marantz Cinema 30, which has 3 zones.
Thanks. I eneded up going with an HTD MCA-66 which has 6 zones and an official integration (that needs some work).
I looked up the HTD MCA-66 and price is ok, but some major drawbacks, no eithernet, have to use a seperate controller to stream and its only through wifi and it requires cloud access.
Hi Alex. I am interested in your Soundavo WS66i. I am in Portugal. Please give me details. [email protected]
It’s sold in the mean time…
