Speaker Audio Media Player in esp32-s3-zero?
Has anyone got Speaker Audio Media Player running on anything like an esp32-s3-zero pls?
I’ve had a nightmare with updates breaking my DIY smart speaker for ages now… towards the end of last year I re-did it from scratch, brute-forcing what worked and what didnt. Had to settle on using the arduino framework and media player, nothing else would work out.
Over the last few months updates to both esphome and HA core break it in various ways again. So I’ve had to stop running the latest versions of both.
I saw mention of the (new?) Speaker Audio Media Player a couple of days ago, so thought I’d give it a try. Just a media player to begin with, which I’d use for various TTS notifications from HA. Then maybe a voice assistant.
I cant get it to make any noise at all, using the example from here, and hardware/connections that have worked with older versions of HA and esphome.
Other than the basic definition of the board, wifi, pins, an LED, I’ve copied/pasted the example.
Has anyone got this example working on anything like an esp32-s3?
Or can anyone see what I’m doing wrong?
Is this just not hardware that can be used for a smart speaker/media player now? Is there any DIY hardware that would work?
The yaml that isn’t working for me:
substitutions:
  friendly_name: Jarvis2
  host_name: jarvis2
  led_brightness:     25%       # RGB LED brightness for simple on/off
  min_led_brightness: 20%       # Min LED brghtness for effects
  max_led_brightness: 40%       # Max LED brghtness for effects
  log_level:      DEBUG         # NONE, ERROR, WARN, INFO, DEBUG (Default), VERBOSE, VERY_VERBOSE
  static_ip:      192.168.5.36  # Static ID details
  static_gateway: 192.168.5.254
  static_subnet:  255.255.255.0
  static_dns:     192.168.5.2
  vol_up_pin:     GPIO12        # Button for Vol+
  vol_down_pin:   GPIO11        # Button for Vol-
  amp_din_pin:    GPIO04        # Amp DIN
  amp_bclk_pin:   GPIO05        # Amp BCLK
  amp_lrc_pin:    GPIO06        # Amp LRC
  rgb_led_pin:    GPIO21        # RGB LED pin, GPIO21 for onboard LED
  no_leds:        "1"           # Number of RGB LEDs, 1 for onboard LED
api:                                    # Enable Home Assistant API.
  encryption:
    key: !secret api_encryption_key
ota:
  platform: esphome # For 2024.6.1+
  password: !secret ota_password
safe_mode: # For 2024.6.1+
esphome:
  friendly_name: $friendly_name
  platformio_options:
    board_build.flash_mode: dio
  on_boot:
    - logger.log:
        level: ERROR
        format: "****Booted"
    - light.turn_on:
        brightness: $led_brightness
        blue: 0%
        red: 100%
        green: 100%
esp32:
  board: esp32-s3-devkitc-1
  flash_size: 4MB
  variant: esp32s3
  framework:
    type: esp-idf
    version: recommended
psram:
  mode: quad
  speed: 80MHz
wifi:                                   # WiFi connection details. Without domain:, defaults to .local. https://esphome.io/components/wifi.html
  ssid: !secret wifi_ssid
  fast_connect: true
  manual_ip:
    static_ip: $static_ip
    gateway: $static_gateway
    subnet: $static_subnet
    dns1: $static_dns
  power_save_mode: none                 # NONE, LIGHT, HIGH
  ap:                                   # Enable fallback hotspot (captive portal) in case wifi connection fails
    ssid: "${friendly_name} Fallback"
    password: !secret fallback_password
captive_portal:
web_server:
  port: 80
  include_internal: true              # include internal entities
  local: true                           # Load everything locally rather than over the web
  - platform: wifi_signal # Reports the WiFi signal strength in dB. https://esphome.io/components/sensor/wifi_signal.html
    name: "WiFi Signal dB"              # Uncomment to show signal DB in HA
    update_interval: 60s                # Report signal every minute
    entity_category: "diagnostic"
    device_class: "signal_strength"
    disabled_by_default: true           # Shows entity in HA, but disabled by default
    internal: true
  - platform: copy                      # Reports the WiFi signal strength %
    source_id: wifi_signal_db
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    unit_of_measurement: "%"
  - platform: uptime
    # update_interval: 10s
    internal: true                    # Uncomment to leave internal and not send to HA
button:
  - platform: restart
  - platform: safe_mode
    name: "Restart (Safe Mode)"
  - platform: factory_reset
    name: Restart with Factory Default Settings
    entity_category: diagnostic
  - platform: shutdown
debug:
  update_interval: 5s
text_sensor:
  # Expose WiFi information as sensors.
  - platform: wifi_info
    ip_address:
      icon: mdi:wifi
    mac_address:
      icon: mdi:wifi
  - platform: version
    icon: mdi:wrench-outline
  - platform: debug
    device:
    reset_reason:
# Sync time with Home Assistant
time:
  - platform: homeassistant
logger:                                 # Enable logging. https://esphome.io/components/logger.html
  level: $log_level
  baud_rate: 0                          # Stops logging over onboard UART
binary_sensor:
  - platform: status
  - platform: gpio
    pin:
      number: $vol_up_pin
      mode:
        input: true
        pullup: true
    filters:
      - invert:
    internal: true
    on_press:
      - media_player.volume_up
      - light.turn_on:
          blue: 100%
          red: 100%
          green: 0%
  - platform: gpio
    pin:
      number: $vol_down_pin
      mode:
        input: true
        pullup: true
    filters:
      - invert:
    internal: true
    on_press:
      - media_player.volume_down
      - light.turn_on:
          blue: 100%
          red: 100%
          green: 0%
light:
  - platform: esp32_rmt_led_strip
    pin: $rgb_led_pin
    num_leds: 1
    # rmt_channel: 0
    rgb_order: GRB
    chipset: ws2812
    default_transition_length: 0ms
    effects:
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
          min_brightness: $min_led_brightness
          max_brightness: $max_led_brightness
      - pulse:
          # transition_length: 1s       # defaults to 1s
          update_interval: 2s
      - pulse:
          transition_length:
            on_length: 1s
            off_length: 500ms
          update_interval: 1.5s
          max_brightness: $led_brightness
      - random:
      - random:
          name: Random, custom timing
          transition_length: 500ms
          update_interval: 2s
      - strobe:
      - strobe:
          name: Strobe Effect, RGBW
          colors:
            - state: true
              red: 100%
              green: 0%
              blue: 0%
              duration: 1000ms
            - state: true
              red: 0%
              green: 100%
              blue: 0%
              duration: 1000ms
            - state: true
              red: 0%
              green: 0%
              blue: 100%
              duration: 1000ms
            - state: true
              red: 100%
              green: 100%
              blue: 100%
              duration: 1000ms
      - flicker:
      - flicker:
          name: Flicker Effect With Custom Values
          alpha: 95%
          intensity: 1.5%
      - lambda:
          update_interval: 1s
          lambda: |-
            static int state = 0;
            auto call = id(rgb_led).turn_on();
            // Transition of 1000ms = 1s
            call.set_transition_length(1000);
            if (state == 0) {
              call.set_rgb(1.0, 1.0, 1.0);
            } else if (state == 1) {
              call.set_rgb(1.0, 0.0, 1.0);
            } else if (state == 2) {
              call.set_rgb(0.0, 0.0, 1.0);
            } else {
              call.set_rgb(1.0, 0.0, 0.0);
            call.perform();
            state += 1;
            if (state == 4)
              state = 0;
      - addressable_rainbow:
      - addressable_color_wipe:
      - addressable_twinkle:
      - addressable_random_twinkle:
i2s_audio:
    i2s_lrclk_pin: $amp_lrc_pin
    i2s_bclk_pin: $amp_bclk_pin
    # sample_rate: 48000
speaker:
  - platform: i2s_audio
    dac_type: external
    i2s_dout_pin: $amp_din_pin
    sample_rate: 48000
  - platform: mixer
    output_speaker: speaker_id
    source_speakers:
      - id: announcement_spk_mixer_input
      - id: media_spk_mixer_input
  - platform: resampler
    output_speaker: media_spk_mixer_input
    output_speaker: announcement_spk_mixer_input
media_player:
  - platform: speaker
    name: "Speaker Media Player"
    media_pipeline:
        speaker: media_spk_resampling_input
        num_channels: 2
    announcement_pipeline:
        speaker: announcement_spk_resampling_input
        num_channels: 1
    files:
      - id: alarm_sound
        file: pip.flac # Placed in the yaml directory. Should be encoded with a 48000 Hz sample rate, mono or stereo audio, and 16 bits per sample.
switch:
    optimistic: true
    restore_mode: ALWAYS_OFF
    on_turn_off:
        # Stop playing the alarm
        - media_player.stop:
            announcement: true
        - mixer_speaker.apply_ducking:  # Stop ducking the media stream over 2 seconds
            decibel_reduction: 0
            duration: 2.0s
    on_turn_on:
        # Duck media audio by 20 decibels instantly
            decibel_reduction: 20
            duration: 0.0s
        - while:
            condition:
                switch.is_on: timer_ringing
            then:
                # Play the alarm sound as an announcement
                - media_player.speaker.play_on_device_media_file:
                    media_file: alarm_sound
                    # announcement: true
                # Wait until the alarm sound starts playing
                - wait_until:
                    media_player.is_announcing:
                # Wait until the alarm sound stops playing
                - wait_until:
                    not:
Thanks a lot
Have a look here.
Its working for me.
Thanks a lot. I’ll see what I can do with it.
(just realised I hadn’t included the esps full name… its an esp32-s3-zero)
Holy carp @Arh, it’s alive!
With current esphome and HA core versions, tied into my local ollama setup!
Thanks so much to you and @steriku for sharing things, this had been such a frustrating pain for me for aaages now.
This seems to be working almost perfectly for me, with one small exception. If I have music playing using the media player and send an announcement at the same time, the music’s volume is ducked low but the announcement doesn’t actually play. Still a massive improvement on what I had though.
Here’s how mine looks so far, in case it’s of any to anyone or anyone can see what’s up with the focus loss ducking:
substitutions:
  host_name: jarvis
  #pins
  amp_lrc_pin:        GPIO06        # LRC on Max98357
  amp_bclk_pin:       GPIO05        # BCLK on Max98357
  mic_ws_pin:         GPIO08        # WS on INMP441
  mic_ck_pin:         GPIO09        # SLK on INMP441
  rgb_led_pin:        GPIO21        # on-board LED
  amp_din_pin:        GPIO04        # DIN on Max98357
  mic_din_pin:        GPIO07        # SD on INMP441
  assist_mic_gain:          31dBFS  # 31dBFS # Assistant mic gain. Between 0dBFS and 31dBFS
  assist_noise_supression:  "4"     # Assistant noise suppression. Between 0 and 4 inclusive
  assist_vol_multiplier:    "8"     # "15" # Assistant volume multiplier. Must be larger than 0. Defaults to 1 (disabled)
  log_level:          ERROR         # NONE, ERROR, WARN, INFO, DEBUG (Default), VERBOSE, VERY_VERBOSE
  static_ip:          192.168.5.35  # Static IP address
  static_gateway:     192.168.5.254 # Static gateway address
  static_subnet:      255.255.255.0 # Static subnet
  static_dns:         192.168.5.2   # Static DNS address
  # Sounds
  # connected_sound:         "http://192.168.5.11:8123/local/Voice_assistant/jarvis_connected.mp3"
  # stop_listening_sound:    "http://192.168.5.11:8123/local/Voice_assistant/ill_stop_listening.mp3"
  # start_listening_sound:   "http://192.168.5.11:8123/local/Voice_assistant/im_listening.mp3"
  pip_sound:               "http://192.168.5.11:8123/local/Voice_assistant/pip.mp3"
  test_sound:              "http://192.168.5.11:8123/local/Voice_assistant/testing_1_2_3_testing.mp3"
  # Phases of the Voice AssistantGPIO8
  # IDLE: The voice assistant is ready to be triggered by a wake-word
  voice_assist_idle_phase_id: '1'
  # LISTENING: The voice assistant is ready to listen to a voice command (after being triggered by the wake word)
  voice_assist_listening_phase_id: '2'
  # THINKING: The voice assistant is currently processing the command
  voice_assist_thinking_phase_id: '3'
  # REPLYING: The voice assistant is replying to the command
  voice_assist_replying_phase_id: '4'
  # NOT_READY: The voice assistant is not ready
  voice_assist_not_ready_phase_id: '10'
  # ERROR: The voice assistant encountered an error
  voice_assist_error_phase_id: '11'
  # MUTED: The voice assistant is muted and will not reply to a wake-word
  voice_assist_muted_phase_id: '12'
#psram:
#  mode: octal
#  speed: 80MHz
psram:
  mode: quad
  speed: 80MHz
packages:
  logger: !include common/logger.yaml
  api_ota: !include common/api_ota.yaml
  wifi: !include common/wifi.yaml
  web_server: !include common/web_server.yaml
  sensor: !include common/sensor.yaml
  binary_sensor: !include common/binary_sensor.yaml
  button: !include common/button.yaml
  text_sensors: !include common/text_sensor.yaml
  time: !include common/sync_time.yaml
  switch: !include common/switch.yaml
  level: ${log_level}
wifi:
  # use_address: "192.168.5.35"
  manual_ip:
    static_ip: ${static_ip}
    gateway: ${static_gateway}
    subnet: ${static_subnet}
    dns1: ${static_dns}
  power_save_mode: HIGH                # NONE, LIGHT, HIGH
  # If the device connects, or disconnects, to the Wifi: Run the script to refresh the LED status
  on_connect:
    - script.execute: control_led
  on_disconnect:
esp32:
  variant: ESP32S3
  framework:
    type: esp-idf
    sdkconfig_options:
      # ESP32-S3 N16R8
      # CONFIG_ESP32_S3_BOX_BOARD: "y"
      # CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      # CONFIG_ESP32S3_DATA_CACHE_64KB:      "y"
      # CONFIG_ESP32S3_DATA_CACHE_LINE_64B:  "y"
      # CONFIG_BT_ALLOCATION_FROM_SPIRAM_FIRST: "y"
      # CONFIG_BT_BLE_DYNAMIC_ENV_MEMORY: "y"
      # CONFIG_MBEDTLS_EXTERNAL_MEM_ALLOC: "y"
      # CONFIG_MBEDTLS_SSL_PROTO_TLS1_3: "y"
      # ESP32-S3-Zero
      CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM: "16"
      CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM: "512"
      CONFIG_TCPIP_RECVMBOX_SIZE: "512"
      CONFIG_TCP_SND_BUF_DEFAULT: "65535"
      CONFIG_TCP_WND_DEFAULT: "512000"
      CONFIG_TCP_RECVMBOX_SIZE: "512"
esphome:
  friendly_name: ${friendly_name}
  on_boot:
      priority: 600
      then:
        # Run the script to refresh the LED status
        # - output.turn_off: set_low_speaker
        # If after 30 seconds, the device is still initializing (It did not yet connect to Home Assistant), turn off the init_in_progress variable and run the script to refresh the LED status
        - delay: 30s
        - if:
            condition:
              lambda: return id(init_in_progress);
            then:
              - lambda: id(init_in_progress) = false;
microphone:
    i2s_din_pin: ${mic_din_pin}
    adc_type: external
    pdm: false
    i2s_audio_id: i2s_in
    channel: left
    # sample_rate: 16000
    # bits_per_sample: 16bit
speaker:
    dac_type: external
    sample_rate: 48000
    i2s_dout_pin:
      number: ${amp_din_pin}
    bits_per_sample: 32bit
    i2s_audio_id: i2s_output
    timeout: never
    buffer_duration: 100ms
    channel: left
    # bits_per_sample: 32bit
  # Virtual speakers to combine the announcement and media streams together into one output
  - platform: mixer
    output_speaker: i2s_audio_speaker
    # num_channels: 2
    num_channels: 1
    source_speakers:
      - id: announcement_mixing_input
        timeout: never
      - id: media_mixing_input
        timeout: never
  # Vritual speakers to resample each pipelines' audio, if necessary, as the mixer speaker requires the same sample rate
    output_speaker: announcement_mixing_input
    sample_rate: 48000
    bits_per_sample: 16
    output_speaker: media_mixing_input
    sample_rate: 48000
    bits_per_sample: 16
media_player:
  - platform: speaker
    internal: False
    volume_increment: 0.05
    volume_min: 0.4
    volume_max: 0.85 # when amp gain connected to ground. Avoids cutting out.
    icon: mdi:speaker-wireless
      speaker: announcement_resampling_speaker
      format: FLAC     # FLAC is the least processor intensive codec
      num_channels: 1  # Stereo audio is unnecessary for announcements
      sample_rate: 48000
    media_pipeline:
      speaker: media_resampling_speaker
      # num_channels: 2
      num_channels: 1
      sample_rate: 48000
    on_announcement:
          duration: 0.0s
    on_state:
      if:
        condition:
          and:
            - not:
                voice_assistant.is_running:
            - not:
        then:
              duration: 1.0s
    files:
      - id: timer_finished_sound
        file: https://github.com/esphome/home-assistant-voice-pe/raw/dev/sounds/timer_finished.flac
      # - id: wake_word_triggered_sound
      #   file: https://github.com/esphome/home-assistant-voice-pe/raw/dev/sounds/wake_word_triggered.flac
        file: wake_word_triggered.flac
      - id: pip_sound
i2s_audio:
  - id: i2s_output
    i2s_lrclk_pin: ${amp_lrc_pin}
    i2s_bclk_pin: ${amp_bclk_pin}
  - id: i2s_in
    i2s_lrclk_pin: ${mic_ws_pin}
    i2s_bclk_pin: ${mic_ck_pin}
voice_assistant:
  microphone: comm_mic
  media_player: external_media_player
  noise_suppression_level: ${assist_noise_supression}
  auto_gain: ${assist_mic_gain}
  volume_multiplier: ${assist_vol_multiplier}
  # use_wake_word: false
  # When the voice assistant connects to HA:
  # Set init_in_progress to false (Initialization is over).
  # If the switch is on, start the voice assistant
  # In any case: Set the correct phase and run the script to refresh the LED status
  on_client_connected:
    - if:
        condition:
          switch.is_on: enable_assistant
        then:
          - micro_wake_word.start
          - lambda: id(voice_assistant_phase) = ${voice_assist_idle_phase_id};
        else:
          - lambda: id(voice_assistant_phase) = ${voice_assist_muted_phase_id};
  # When the voice assistant disconnects to HA:
  # Stop the voice assistant
  # Set the correct phase and run the script to refresh the LED status
  on_client_disconnected:
    - lambda: id(voice_assistant_phase) = ${voice_assist_not_ready_phase_id};
    - micro_wake_word.stop
  # When the voice assistant starts to listen: Set the correct phase and run the script to refresh the LED status
  on_listening:
    - lambda: id(voice_assistant_phase) = ${voice_assist_listening_phase_id};
  # When the voice assistant starts to think: Set the correct phase and run the script to refresh the LED status
  on_stt_vad_end:
    - lambda: id(voice_assistant_phase) = ${voice_assist_thinking_phase_id};
  # When the voice assistant starts to reply: Set the correct phase and run the script to refresh the LED status
  # on_tts_stream_start:
  on_tts_start:
    - lambda: id(voice_assistant_phase) = ${voice_assist_replying_phase_id};
  on_end:
    - if:
        condition:
          - switch.is_on: enable_assistant
        then:
          - wait_until:
              not:
  # When the voice assistant finished to reply: Set the correct phase and run the script to refresh the LED status
  # on_tts_stream_end:
  # on_stt_end:
  # When the voice assistant encounters an error:
  # Set the error phase and run the script to refresh the LED status
  # Wait 1 second and set the correct phase (idle or muted depending on the state of the switch) and run the script to refresh the LED status
  on_error:
    - if:
        condition:
          lambda: return !id(init_in_progress);
        then:
          - lambda: id(voice_assistant_phase) = ${voice_assist_error_phase_id};
          - delay: 1s
          - if:
              condition:
              then:
              else:
micro_wake_word:
  models:
    - hey_jarvis
  vad:
  on_wake_word_detected:
    - if:
        condition:
        then:
          - if:
              condition:
              then:
                voice_assistant.stop:
              # Stop any other media player announcement
              else:
                - if:
                    condition:
                    then:
                          announcement: true
                    # Start the voice assistant and play the wake sound, if enabled
                    else:
                      - script.execute:
                          priority: true
                          sound_file: !lambda return id(wake_word_triggered_sound);
                      - delay: 300ms
                      - voice_assistant.start:
                          wake_word: !lambda return wake_word;
globals:
  # Global initialisation variable. Initialized to true and set to false once everything is connected. Only used to have a smooth "plugging" experience
  - id: init_in_progress
    type: bool
    restore_value: no
    initial_value: 'true'
  # Global variable tracking the phase of the voice assistant (defined above). Initialized to not_ready
  - id: voice_assistant_phase
    type: int
    restore_value: no
    initial_value: ${voice_assist_not_ready_phase_id}
light:
    pin: ${rgb_led_pin}
    chipset: WS2812
    max_refresh_rate: 15ms
    num_leds: ${no_leds}
    rgb_order: GRB
    rmt_symbols: 192
    effects:
      - pulse:
          transition_length: 250ms
          update_interval: 250ms
          min_brightness: 50%
          max_brightness: 100%
      - pulse:
          transition_length: 100ms
          update_interval: 100ms
          min_brightness: 50%
      - pulse:
          transition_length:
            on_length: 1s
            off_length: 500ms
          min_brightness: ${min_led_brightness}
          max_brightness: ${led_brightness}
      - random:
      - random:
          update_interval: 2s
      - strobe:
      - strobe:
          colors:
            - state: true
              red: 100%
              green: 0%
              blue: 0%
              duration: 1000ms
            - state: true
              red: 0%
              green: 100%
              blue: 0%
              duration: 1000ms
            - state: true
              red: 0%
              green: 0%
              blue: 100%
              duration: 1000ms
            - state: true
              red: 100%
              green: 100%
              blue: 100%
              duration: 1000ms
      - flicker:
      - flicker:
          alpha: 95%
          intensity: 1.5%
      - lambda:
          update_interval: 1s
          lambda: |-
            auto call = id(led).turn_on();
            if (state == 0) {
            } else {
            call.perform();
            state += 1;
            if (state == 4)
              state = 0;
script:
  # Master script controlling the LED, based on different conditions: initialization in progress, wifi and API connected, and the current voice assistant phase.
  # For the sake of simplicity and re-usability, the script calls child scripts defined below.
  # This script will be called every time one of these conditions is changing.
  - id: control_led
    then:
      - if:
          condition:
          then:
            - if:
                condition:
                  wifi.connected:
                then:
                  - if:
                      condition:
                        api.connected:
                      then:
                        - lambda: |
                            switch(id(voice_assistant_phase)) {
                              case ${voice_assist_listening_phase_id}:
                                id(control_led_voice_assist_listening_phase).execute();
                                break;
                              case ${voice_assist_thinking_phase_id}:
                                id(control_led_voice_assist_thinking_phase).execute();
                                break;
                              case ${voice_assist_replying_phase_id}:
                                id(control_led_voice_assist_replying_phase).execute();
                                break;
                              case ${voice_assist_error_phase_id}:
                                id(control_led_voice_assist_error_phase).execute();
                                break;
                              case ${voice_assist_muted_phase_id}:
                                id(control_led_voice_assist_muted_phase).execute();
                                break;
                              case ${voice_assist_not_ready_phase_id}:
                                id(control_led_voice_assist_not_ready_phase).execute();
                                break;
                              default:
                                id(control_led_voice_assist_idle_phase).execute();
                                break;
                      else:
                        - script.execute: control_led_no_ha_connection_state
                else:
          else:
            - script.execute: control_led_init_state
  # Script executed during initialisation: In this example: Turn the LED in green with a slow pulse 🟢
  - id: control_led_init_state
    then:
      - light.turn_on:
          blue: 0%
          red: 0%
          green: 100%
          effect: "Fast Pulse"
  # Script executed when the device has no connection to Home Assistant: In this example: Turn off the LED
  - id: control_led_no_ha_connection_state
    then:
      - light.turn_off:
  # Script executed when the voice assistant is idle (waiting for a wake word): In this example: Turn the LED in white with 20% of brightness ⚪
  - id: control_led_voice_assist_idle_phase
    then:
      - light.turn_on:
          blue: 100%
          red: 100%
          green: 100%
          brightness: 20%
          effect: "none"
  # Script executed when the voice assistant is listening to a command: In this example: Turn the LED in blue with a slow pulse 🔵
  - id: control_led_voice_assist_listening_phase
    then:
      - light.turn_on:
          blue: 100%
          red: 0%
          green: 0%
          effect: "Slow Pulse"
  # Script executed when the voice assistant is processing the command: In this example: Turn the LED in blue with a fast pulse 🔵
  - id: control_led_voice_assist_thinking_phase
    then:
      - light.turn_on:
          blue: 100%
          red: 0%
          green: 0%
  # Script executed when the voice assistant is replying to a command: In this example: Turn the LED in blue, solid (no pulse) 🔵
  - id: control_led_voice_assist_replying_phase
    then:
      - light.turn_on:
          blue: 100%
          red: 0%
          green: 0%
          brightness: 100%
          effect: "none"
  # Script executed when the voice assistant encounters an error: In this example: Turn the LED in red, solid (no pulse) 🔴
  - id: control_led_voice_assist_error_phase
    then:
      - light.turn_on:
          blue: 0%
          red: 100%
          green: 0%
          brightness: 100%
          effect: "none"
  # Script executed when the voice assistant is muted: In this example: Turn off the LED
  - id: control_led_voice_assist_muted_phase
    then:
      - light.turn_off:
  # Script executed when the voice assistant is not ready: In this example: Turn off the LED
  - id: control_led_voice_assist_not_ready_phase
    then:
      - light.turn_off:
  # Script executed when we want to play sounds on the device.
  - id: play_sound
    parameters:
      priority: bool
      sound_file: "audio::AudioFile*"
    then:
      - lambda: |-
          if (priority) {
            id(external_media_player)
              ->make_call()
              .set_command(media_player::MediaPlayerCommand::MEDIA_PLAYER_COMMAND_STOP)
              .set_announcement(true)
              .perform();
          if ( (id(external_media_player).state != media_player::MediaPlayerState::MEDIA_PLAYER_STATE_ANNOUNCING ) || priority) {
              ->play_file(sound_file, true, false);
switch:
    name: Enable Assistant
    icon: mdi:microphone-message
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    # icon: mdi:assistant
    # When the switch is turned on (on Home Assistant):
    # Start the voice assistant component
    on_turn_on:
      - if:
          condition:
          then:
            - if:
                condition:
                  not:
                    - voice_assistant.is_running
                then:
    # When the switch is turned off (on Home Assistant):
    # Stop the voice assistant component
    on_turn_off:
      - if:
          condition:
          then:
            - voice_assistant.stop
button:
    icon: "mdi:speaker-play"
    on_press:
      - media_player.play_media: $test_sound
    on_press:
      - script.execute:
          priority: true
    on_press:
      - script.execute:
          priority: true
          sound_file: !lambda return id(pip_sound);
packages: doesn’t include anything exotic, just the basics that are common to most/all of my esphome devices
Did you solve this issue, if not I think I found a workaround. The issue is restricting how much of a buffer the media_player tries to allocate.
If you set the logger to debug.
# Enable logging
logger:
  level: DEBUG
And then run the test again, you should see an error about not enough memory. I got this when I played music through the speaker, stopped the music and then activate the assistant, the assistant would not speak because of the memory allocation error.
After messing around for what it seemed like weeks pushing everything to PSRAM someone mentioned about a setting about buffer_size without context of where its set. I found that the media_player has this parameter. So I set it as the following, just selecting 50% of what the default value is. Now I did this with some knowledge of how much available PSRAM there was because I enabled reporting of free PSRAM from debug. Point being when it worked, I stopped debugging, there may be a value somewhere between 500000 and the default of 1000000 that is ideal.
buffer_size: 500000
