Speaker makes noise after boot
Hi everyone,
i connected a speaker to my esphome project via a MAX98357A. i use the this project as a voice assistant satellite.
Everything is working but after booting but before the first response from the voice assistant, the speaker makes strange noises.
i try to post my yaml but its a bit tricky because i use packages and substitutions.
esphome:
  friendly_name: DeepThought
  min_version: 2025.9.0
  name_add_mac_suffix: false
esp32:
  variant: esp32
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
wifi:
  ssid: !secret wifi_ssid
captive_portal:
substitutions:
  <<: !include substitutions.yaml
  dht_name: "Deepthought"
  update_interval: 60s
#  lambda: |-
#      it.printf(0, 0, "Test: %.1fC", id(ha_temp).state);
#      it.printf(0, 1, "Deep Thought");
packages:
  dht_sensor: !include packages/dht22.yaml
  wifisignal: !include packages/wifisignal.yaml
  ledcoutput: !include packages/singleled.yaml
  i2c: !include packages/i2c.yaml
  lcd_display: !include packages/i2c_16x2_lcd.yaml
  lcd_textsensor_2line: !include packages/lcd_textsensor_2line.yaml
  i2s_audio: !include packages/i2s_audio.yaml
  microphone: !include packages/microphone.yaml
  speaker: !include packages/speaker.yaml
light:
  - platform: monochromatic
    output: led_output
voice_assistant:
  microphone: mic_i2s
  noise_suppression_level: 2
#  auto_gain: 31dBFS
#  volume_multiplier: 20.0
  use_wake_word: True
  speaker: my_speaker
  on_error:
   - if:
        condition:
          switch.is_on: use_wake_word
        then:
          - switch.turn_off: use_wake_word
          - switch.turn_on: use_wake_word
  on_client_connected:
    - speaker.volume_set: 100%
    - if:
        condition:
        then:
          - voice_assistant.start_continuous:
  on_client_disconnected:
    - if:
        condition:
        then:
          - voice_assistant.stop:
  # >>> LED-Steuerung <<<
  on_listening:
    - light.turn_on: assistant_led
  on_tts_start:
  on_tts_end:
    - light.turn_off: assistant_led
  on_end:
binary_sensor:
  - platform: status
    name: API Connection
    filters:
      - delayed_on: 1s
    on_press:
      - if:
          condition:
          then:
    on_release:
      - if:
          condition:
          then:
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    entity_category: config
    on_turn_on:
      - lambda: id(va).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
    on_turn_off:
  - platform: homeassistant
    entity_id: sensor.esphome_web_6fe1d4_deepthought_temperature
speaker package:
speaker:
  - platform: ${speaker_platform}
    dac_type: ${speaker_dac_type}
    i2s_dout_pin: ${speaker_i2s_dout_pin}   #DIN
    i2s_audio_id: ${speaker_i2s_audio_id}
    i2s_mode: ${speaker_i2s_mode}
after the first response of the voice assistant the noise is off and from then on it works nicely, so i need help to “start” the speaker with a noise or something from home assistant that it stops the noise.
i hope that i was clear my english is not the best.
