SpeakerCraft MZC Control
Yea I’ve had all the parts turn up, I’ve joined the 3 wires following that diagram for now but came to a stand still at wire number 4. I can give it a go as is and see if it works I guess - as long as it won’t fry anything? Wondering weather a normal 3.5mm trs jack would have worked if you only need 3 wires, instead of trrs which I went out of my way to find.
I apologize, Life got in the way and I haven’t had a chance to look yet. I do know that what is available at the Bezos’ Family Store does not have the correct pinout. I found this that I’d made 4 years ago and assume it is still valid. I’ll try to pull out my cable and test it later. What I did is use an RJ45 (Ethernet) cable to put the tip on and connect to the DB9 adapter. This way I can extend the cable if needed.
It does look like only 3 of the 4 are actually used though.
On another note, is anyone else having an issue with this Home Assistant needing to be rebooted after a time to see this integration again?
I’ve tried quite a few times now to get the MZC-88 working in EZ tools but it has never worked. I go to tools>Update products firmware but always get a message “Failed to SetCommState for COM Port #3” or “serial port is not open”. Also tried all of my laptop USB ports.
I’m 99% sure I’ve wired the correct pins. Tip = white, Red = second sleeve, Green = third sleeve, Yellow I get no continuity when I test anywhere along the 3.5mm jack but I read it’s just another ground so I figured connect them together? There is a G labelled on the green terminal block in the picture which is connected to the silver metal part of the DB9 connector where it joins to the next adaptor. I’ve also tried swapping the red and white wires, and tied variations with the green/yellow on G or 5, nothing changes. I’ve tried firmware update switch on the MZC-88 in both the on and off position along the way.
I’m wondering whether it could be a driver issue on my computer? I tried playing with the baud rate too. Can someone check if they have different drivers they are using or recommend where I might find the right ones if mine aren’t correct? I don’t know much about them.
If it’s not a driver issue I suspect it may be the cables just not communicating as they should. Good fun trying to get obsolete technology working again in the modern day…
I’d like this please, if you still have it? lol :smile:
So after upgrading HA to 2025.1 this integration has stopped working. Any plans to update the code?
More Details on the error:
Logger: homeassistant.helpers.frame
Source: helpers/frame.py:188
First occurred: January 5, 2025 at 3:04:00 AM (3 occurrences)
Last logged: January 5, 2025 at 3:04:14 AM
  • Detected that custom integration ‘speakercraft_media’ accesses hass.helpers.discovery. This is deprecated and will stop working in Home Assistant 2024.11, it should be updated to import functions used from discovery directly at custom_components/speakercraft_media/init.py, line 107: hass.helpers.discovery.load_platform(‘media_player’, DOMAIN, {}, config),
Looks like there is an issue open:
https://github.com/mattsaxon/HASS-SpeakercraftMediaPlayer/issues/54
I have no idea how to code in Python but it seems to be these four lines of code that cause the problem.
||hass.helpers.discovery.load_platform('media_player', DOMAIN, {}, config)|
||hass.helpers.discovery.load_platform('switch', DOMAIN, {}, config)|
||hass.helpers.discovery.load_platform('button', DOMAIN, {}, config)|
||hass.helpers.discovery.load_platform('number', DOMAIN, {}, config)|
Since hass.helpers has been deprecated how would these lines be changed to get the integration to work properly?
I’ve submitted a pull request that I think fixes the following:
HA 2025.1 - https://github.com/mattsaxon/HASS-SpeakercraftMediaPlayer/issues/54
HA2025.5 (I think that’s when it’ll stop working) - Those four lines of code you’ve pointed out.
Pull Request here in case you want to copy and paste the code in manually:
https://github.com/mattsaxon/HASS-SpeakercraftMediaPlayer/pull/55
Hey Johan - I tested the revised code with HA 2025.1 and it works perfectly. Thanks so much for that. I’m not sure if the integration will be supported anymore but at least I have a few months to either learn Python or replace MZC66 :slight_smile:
Just wanted to give a big thanks to Sjeffrey and mattsaxon and everyone else on this thread for creating and continuing to maintain this integration. I’ve had my MZC66 for years, I had integrated it with HA via ESP32 IR blaster using scripts to send the unique zone, source, volume commands, but always a bit unpredictable. Moved to a new house, brought the MZC with me and figured it was time to improve. Picked up a Ethernet-RS232, hooked it all up, installed the code, made a few tweaks to incorporate the changes in HA and this worked amazingly. Kudos to all of you for helping give these Speakercraft systems meaningful lives in our HA world!
Good morning, Guys, I love the work you have done here, I’m going to try this in a few months, I was wondering if you guys have the EZ tools Software available for download?
I was able to find a working version via the wayback machine. You may also need the firmware updater depending on which version your MZC-66 is running. That’s not the newest version of the firmware, but it’s new enough to use with EZ-Tools.
I discovered that you need firmware version 2.2.8 in order to use this integration - you can get that firmware here. You’ll also need a newer version of EZTools once the firmware is updated.
I’ve just merged @johanlzh changes in Github. Thankyou for doing this change, testing etc.
Sorry i have been vacant recently. I’ve moved home and dont have the MZC plugged in currently. Its a shame it stopped working with the HA updates, but hopefully now its all good again. I’ll try and keep a closer eye on this topic and any merge requests.
Although i dont use this components currently i dont want it to die either as i put alot of work into it and still think its a great AMP especially when controlled through HA.
Not sure if @mattsaxon is using this still or not either.
