Speech-to-phrase fallback to faster-whisper (no cloud)
Replace my google voices with Home Assistant Nabu. I ran speech-to-phrase for a while, but since you need exact phrases sometimes it failed to understand. I then switched over to whisper, but smaller models have worse voice to text understanding than speech to phrase for some reason. Faster-whisper-medium has perfect voice recognition for me and executes things well but on my server it runs quite slow.
Is there anyway I can run speech-to-phrase and then fallback to faster-whisper-medium when speech-to-phrase fails to understand a command? I tried looking up but it seems all fallback documentation and discussions are only if you are using a cloud based option that falls back to local.
I have both running in docker containers right now and have nabu activate speech and jarvis activate whisper.
Anyway to fallback within the Wyoming protocol itself or anything like that?
Of course, after spending hours looking over the past few weeks. After I crack and decide to post this I found the solution. Seems there is no built in integration in HA.
I ended up implementing Add stt-fallback by danielrheinbay · Pull Request #17 · rhasspy/wyoming-addons · GitHub which works great. Hope this will be merged eventually.
This also seems to be an alternative solution for anyone else trying to find the answer.
