Split in Automation Template
Hello everyone, I’m currently trying to create a template in an automation.
I have 2 values,
Value1:
input_text.notification_to_processing
(Alexa: This is a test 8)
Value2:
input_text.benstufen_david
(Debug: Info: Alexa:)
I want from
Remove the first part before the : and then compare whether this part is present in input_text.benstufe_david.
condition: template
value_template: "{{ states('input_text.notification_for_processing').split(':')[1] in states('input_text.benstufe_david') }}"
I always get the following error:
In 'template' condition: TypeError: 'in <string>' requires string as left operand, not LoggingUndefined`
What am I doing wrong? Does anyone have a hint?
To understand you right: You want to check, if the word „Alexa“ is in input_text.benstufen_david ?
If so, copy and paste the following into Developer Tools —> Template:
{% set n = states('input_text.notification_to_processing').split(':')[0] %}
{% set b = states('input_text.benstufen_david') %}
{{ n }}
{{ b }}
{{ b is search(n, ignorecase=true) }}
@pedolsky
Yes right!
That works great! Thank you very much :slight_smile:
