Split persistant notification?
I would like to be able to split a persistent notification. Does anyone know if this is possible?
Goal: Receive an ip-trace link on mobile device as soon as someone tries to login using a faulty password. I currently have to following automation setup which sends a notification to my Android phone using Pushbullet:
- alias: "Send notification upon failed login attempt"
    - platform: state
      entity_id: persistent_notification.httplogin
  condition:
    - condition: template
      value_template: "{{ trigger.to_state.state != off }}"
    - service: notify.pushbullet
      data_template:
        message: "{{ trigger.to_state.state }}"
After I received the notification, I extracted the IP addres using Tasker and created an ip-tracker link with the IP address.
Since some time, Pushbullet won’t let me paste the notification to my clipboard so I can’t use it in tasker anymore (only if I pay $5 a months which I think is to much).
I figured I could make a workaround for this if I can send the complete link directly from hass. The only problem is that when a persistent notification is created, it has no attribute with the IP address.
Only a state:
Login attempt or request with invalid authentication from 123.456.78.9
I have to find a way to extract the IP address so I can send the complete link from Hass:
    title: Send URL
    message: Failed login attempt!
      url: http://www.ip-tracker.org/locator/ip-lookup.php?ip=123.456.78.9
Idealy would be to put the IP in a sensor I suppose:
    title: Send URL
    data_template:
      url: http://www.ip-tracker.org/locator/ip-lookup.php?ip={{ states.sensor.ip_address.state  }}
I hope someone can point me in the right direction.
Reallly, no one? :frowning:
Fixed it
    - platform: state
  condition:
        title: "Failed Home Assistant login attempt!"
        data_template:
          url: http://www.ip-tracker.org/locator/ip-lookup.php?ip={{ states.persistent_notification.httplogin.state.split ("from ") [1]}}
