I followed this documentation: https://www.home-assistant.io/integrations/rpi_gpio/ and created this configuration:
switch:
- platform: rpi_gpio
invert_logic: true
ports:
20: Amplifier - Sound
21: Amplifier - Power
22: Anchor Light
23: IR Light
It works, but I don’t like the fact that all the switches are bundled together under the same block, so I tried the following:
switch:
invert_logic: true
ports:
invert_logic: true
ports:
22: Anchor Light
23: IR Light
It still didn’t unbundle it. Putting two separate “Switch” sections doesn’t work at all.
In both cases above my UI looks like the Left hand side. What is the right config to achieve the right-hand-side?
Thanks!
