This dashboard references the following entities, which are unknown to Home Assistant:
button.smarttag1_ring
It doesn’t ring a bell (pun), but I don’t recall ever creating this entity. I did a grep of every file in /config and found this in two files in .storage:
Delete it, let God sort it out was my take on weird ones like that…
Some I knew, some not.
Using Studio code server I found most of it, but if I couldn’t remember, I made sure I had a backup and just killed them.
(I had almost 70 errors at one point)
Entities which are “exposed” You Could also find in /Settings/Voice-Assistant, And you might be able to “Delete” it from the “homeassistant.exposed_entities” file through the UI this way
As for the “Dashboard” file, This could be “related” to i.e a " template or i.e auto-entities-card",
( where this “exposed-added-Entity” ( button.smarttag1_ring) is “Called” ( Meaning it’s really not hard-coded in the Dashboard, but “loaded” from a template/auto-load function in a card" or similar
Seems like an “open” entry, something in “edit mode”
But you really need to “specify” whether you have a dashboard like this “Name” hasp / lab1 , etc ,
If for some reason you don’t have such a dashboard " lovelace.lovelace.hasp " , In your Views , You should be safe to just delete it from the .storage folder
Disregard above if you don’t feel comfortable to also edit i.e the lovelace.lovelace/lovelace_dashboards files
Spook have “spooked” me before, claiming i had an “entity” somewhere, as You i had no idea what “Homie” was talking about, as i didn’t have “such” an entity anymore …
Turned out he was right ( Homie needs an AI-friend, who can fix such, or specify more specific )
