Spotify Connect Addon: OAuth needed - how?
Hi Guys,
I think I am missing something out. I recently installed Spotify Connect (after a long time of not using it etc)
According to the logs OAuth is needed but to be honest I dont know how to do Oauth with this AddOn.
I followed the Documentation but I am pretty sure it just hasnt been updated since OAuth is mandatory for this.
See Log of the Addon:
Add-on: Spotify Connect
Play Spotify music on your Home Assistant device
Add-on version: 0.14.0
You are running the latest version of this add-on.
System: Home Assistant OS 15.2 (amd64 / qemux86-64)
Home Assistant Core: 2025.5.1
Home Assistant Supervisor: 2025.05.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
Log level is set to DEBUG
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun spotifyd (no readiness notification)
[15:10:41] INFO: Starting the Spotify daemon...
s6-rc: info: service legacy-services successfully started
[2025-05-13T13:10:41Z INFO librespot] librespot 0.6.0 VERGEN_IDEMPOTENT_OUTPUT (Built on 2025-02-16, Build ID: CBriaD8k, Profile: release)
[2025-05-13T13:10:41Z TRACE librespot] Command line argument(s):
[2025-05-13T13:10:41Z TRACE librespot] bitrate "320"
[2025-05-13T13:10:41Z TRACE librespot] initial-volume "80"
[2025-05-13T13:10:41Z TRACE librespot] name "Home Assistant"
[2025-05-13T13:10:41Z TRACE librespot] username "XXXXXXXX"
[2025-05-13T13:10:41Z TRACE librespot] password "XXXXXXXX"
[2025-05-13T13:10:41Z TRACE librespot] autoplay "on"
[2025-05-13T13:10:41Z TRACE librespot] disable-audio-cache
[2025-05-13T13:10:41Z TRACE librespot] verbose
[2025-05-13T13:10:41Z ERROR librespot] Invalid `--password` / `-p`: Password authentication no longer supported, use OAuth
[15:10:41] WARNING: spotifyd crashed, halting add-on
s6-rc: info: service legacy-services: stopping
[15:10:41] INFO: spotifyd stoped, restarting...
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Thx in advance…
Hello The-May,
If you are using some add-on, those are written by others and supported there, so I would check there first.
There is a spotify core integration, have you tried that?
Hi @Sir_Goodenough
I know the differences of Addons and Integrations.
Bottom line in this case:
Integration gives me control, Addon gives me Sound out.
So there is no way the Integration here fulfills my needs.
Frenck is the maintainer, therefore I thought I might ask here first before creating a github Issue to make sure it is not a problem with my configuration, since I dont know what to do with oauth.
Oh I see it is just broken and Oauth is a pain in the butt to configure. Yeah well… next time I am going to watch if there is a potential relation in unrelated issues… :slight_smile: I guess the solution is that there is no solution. What a real bummer… thx @VietNgoc
