I’m struggling to get Spotify to authenticate and complete the integration.
I have my developer account all setup and can see the API via the Spotify console and the app in the dashboard
HA though is getting the wrong redirect URL in the authenticate request (http://xxxx.duckdns.org.uk/api/spotify rather than https) - but if I fix that the response causes a return error…
# 500 Internal Server Error
Server got itself in trouble
HA logs has :-
020-01-12 13:26:26 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 40, in real_ip_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 73, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 136, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 120, in handle
result = handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/spotify/media_player.py", line 157, in get
self.oauth.get_access_token(request.query["code"])
File "/usr/local/lib/python3.7/site-packages/spotipy/oauth2.py", line 218, in get_access_token
raise SpotifyOauthError(response.reason)
spotipy.oauth2.SpotifyOauthError: Bad Request
Any suggestions ?
