Does anyone have any insight on what is a good way to determine what the auto cleaning interval of an SPS30 AQ sensor should be? I suspect the more it runs, the quicker it will fail, but going too long will result in bad readings. I’m assuming that the broad answer is "depends on the environment you are using it in? But are there any guard rails that can be put up to help with that answer? In a typical home?
