I’m trying to create sensors to display the last two times that a binary_sensor
was on
. (i.e., one sensor showing the timestamp of the last ‘on’ event, one sensor showing the timestamp of the second-to-last ‘on’-event). I figured that this info is already present in the database and just needs to be read, so I created an SQL sensor with the following query:
SELECT from_unixtime(states.last_updated_ts) as last_updated_ts FROM states, states_meta
WHERE states_meta.entity_id in ("binary_sensor.haustur_opening")
AND states.metadata_id = states_meta.metadata_id
AND states.state = "on"
ORDER BY states.last_updated_ts DESC
LIMIT 1;
As far as I can tell, this works well, and I could easily change the LIMIT
to get the next value. The raw database output is fed into a value_template
that looks like this: {{ (value|as_datetime|as_local).isoformat() }}
The sensor value I get from this is 2025-04-18T09:11:42.906999+02:00
. As far as I know, this is exactly the ISO 8601 string representing the time stamp.
When I set the device_class
of the sensor to timestamp
, however, I get the following error message in the log:
Logger: homeassistant.components.sensor
Quelle: helpers/entity_platform.py:633
Integration: Sensor (Dokumentation, Probleme)
Erstmals aufgetreten: 14:12:21 (1 Vorkommnisse)
Zuletzt protokolliert: 14:12:21
Error adding entity sensor.zeitpunkt_der_letzten_hausturoffnung for domain sensor with platform sql
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 573, in state
if value.tzinfo is None:
AttributeError: 'str' object has no attribute 'tzinfo'
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 633, in _async_add_entities
await coro
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 972, in _async_add_entity
await entity.add_to_platform_finish()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1384, in add_to_platform_finish
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1023, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1148, in _async_write_ha_state
self.__async_calculate_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1085, in __async_calculate_state
state = self._stringify_state(available)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1029, in _stringify_state
if (state := self.state) is None:
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 584, in state
raise ValueError(
...<2 lines>...
) from err
ValueError: Invalid datetime: sensor.zeitpunkt_der_letzten_hausturoffnung has timestamp device class but provides state 2025-04-18T09:11:42.906999+02:00:<class 'str'> resulting in ''str' object has no attribute 'tzinfo''
The sensor becomes unavailable.
I tried removing the milliseconds, but that didn’t change anything. Any ideas?
