SQL lookup of kWh from Solar/Battery into the Energy tab?
I have an SQL(MariaDB) database getting updated every few seconds with lots of solar and battery systems. I have an SELECT statement that will return a total kWh today on any device I want. This works fine as an SQL integration, but I can’t make any of them selectable in the Energy tab.
Aka, I go to Energy tab to add a battery, but I can’t get my battery to appear. I do have the “Unit of Measure” set to kWh in and the SQL statement is working.
All the smart plugs I have show up fine.
What else do I have to do to make it show up?
Using Customize, add:
sensor.one_of_your_energy_sensors:
  state_class: total_increasing
  device_class: energy
sensor.another_one_of_your_energy_sensors:
etc...
You could open a feature request for the SQL sensor to support device and state classes.
Thank you. You sent me down the path that may have solved the issue.
Any extra columns sent in an SQL select statement are treated as attributes. If I include them in my select statement, it seems to work.
select ABS(round(sum(((volts*current)/3600*10))/1000,3)) AS kWh, "energy" AS device_class, "total_increasing" AS state_class FROM batt1 WHERE current < 0.01 AND timestamp >= CURDATE() - INTERVAL 1 DAY;
The above line is what I am trying out, but I am not sure I have the math right. It sums up all the kw used in a day period. It makes the assumption that the database updates every 10 seconds with new information.
< sets it to show used kWh.
> sets it to show charged kWh.
I have the charge controllers added the same way. I am interested to see what HA shows since I don’t have any loads added. I am off-grid, so the entire house is a load. Not sure how to add that.
For anyone looking to integrate their off-grid system. The Energy tab, as of 2022.8, is really designed for on-grid applications and reading from a power meter. If you don’t have the power meter integration, you don’t get much. I have the solar working and I get the “Solar Production” bar chart in kWh. And with the batteries, there is a table with in/out of kWh. But that is it.
What else is there for off-grid?
Solar energy supplied, battery energy discharged and battery energy charged.
You could add a generator in the grid connection I suppose.
Different numbers are important for off-grid then for on-grid.
The “Solar Production” bar chart is near pointless in off-grid. Once the batteries get full, solar production drops to cover the loads. So my 7kw array drops to 600 watts of output.
My battery total is 4.55kWh right now. Since I have used 4.55kWh out of the bank, I would expect that number to be negative, but regardless, that number itself tells me little.
I am not complaining as I am sure it works great for on-grid as that is what it is targeted for. But the numbers I really want is not kWh, but watts and state of charge. I need to know the state of charge of my batteries, along with solar panel output. Will the batteries will get fully charged today? Or will it not happen and do I need to cut back? Do I have an abnormally large load going right now?
I have all that information in HA and/or Grafana. Just not the Energy tab in HA.
Well you are not going to get Watts as that is power. It’s the Energy Dashboard, not Power Dashboard.
You can make your own dashboard.
